430 【原创】我用430做串口通讯,老是丢数据,怎么回事?
问
我用430F149做异步串口传送程序,在发送数据的时候总是出现丢数据的现象,一直不知道怎么回事。我的程序如下:
void RS232_Init(void)
unsigned int i;
P3SEL |= 0x30; // P3.4,5 = USART0 TXD/RXD
P3DIR |= BIT4;
P3DIR &= ~BIT5;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
BCSCTL1 &= ~XT2OFF; // XT2on
BCSCTL2 |= SELS;
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG)); // OSCFault flag still set?
BCSCTL1 |= SELM_2 + SELS; // MCLK = SMCLK = XT2 (safe)
ME1 |= UTXE0 + URXE0; // Enable USART0 TXD/RXD
UCTL0 |= CHAR; // 8-bit character
UTCTL0 |= SSEL1; // 波特率发生器的时钟 = SMCLK
UBR00 = 0xA0; // 8Mhz/19200 ~ 417
UBR10 = 0x01; //
UMCTL0 = 0x00; // no modulation
UCTL0 &= ~SWRST; // Initialize USART state machine
void T_TXD(unsigned char byte)
while ((IFG1&UTXIFG0) == 0);
TXBUF0 = byte;
while((UTCTL0&BIT0) == 0);
unsigned char R_RXD(void)
unsigned char byte;
while((IFG1&URXIFG0) == 0);
byte = RXBUF0;
return(byte);
如果我连续发送数据,就会有丢数据的现象,接收没有问题,各位大虾,帮帮我!!HELP ME!! 答 1: 把
去掉试试 答 2: 哪些情况可能出现丢数据的情况呢?斑竹请分析分析。
unsigned int i;
P3DIR |= BIT4;
P3DIR &= ~BIT5;
BCSCTL2 |= SELS;
do
UBR10 = 0x01; //
TXBUF0 = byte;
unsigned char byte;
byte = RXBUF0;
return(byte);
