AD AD转换采用序列多次采样模式,怎么停止呢?(请看下面的程序)
问
#include "MSP430xG43x.h" // Standard Equations
Results EQU 0200h ; Begining of Results table
main ORG 01100h ; Program Start
RESET mov #0A00h,SP ; Initialize stack pointer
StopWDT mov #WDTPW+WDTHOLD,&WDTCTL ; Stop watchdog
bis.b #BIT0,&P6SEL ; Enable A/D channel A0
SetupADC12 mov #SHT0_8+MSC+ADC12ON,&ADC12CTL0
; Turn on ADC12, use int. osc.
; Extend sampling period to avoid
; overflow
; Set MSC so conversions triggered
; automatically
mov #SHP+CONSEQ_2,&ADC12CTL1
; Use sampling timer, set mode
mov #BIT0,&ADC12IE ; Enable ADC12IFG.0 for ADC12MEM0
eint ; Enable interrupts
clr R5 ; Clear results table pointer
Mainloop bis #ENC,&ADC12CTL0 ; Enable conversions
bis #ADC12SC,&ADC12CTL0 ; Start conversions
bis #CPUOFF,SR ; Hold in LPM0
nop ; Need only for C-SPY
ADC12ISR ; Interrupt Service Routine for ADC12
mov &ADC12MEM0,Results(R5) ; Move result, IFG is reset
incd R5 ; Increment results table pointer
and #0Eh,R5 ; Modulo pointer
reti ;
不明白一点,每次都是中断,中断完了以后就进入低功耗,那这种中断什么时候才是个结束呢?
请指点。谢谢
; Interrupt Vectors
ORG 0FFFEh ; MSP430 RESET Vector
DW RESET ;
ORG 0FFEEh ; ADC12 Interrupt Vector
DW ADC12ISR ;
END
; overflow
; automatically
reti ;
请指点。谢谢
; Interrupt Vectors
DW RESET ;
DW ADC12ISR ;
END
有奖活动 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
