149,8583 【原创】求149对8583的读写C语言程序
问
我自己写得程序总是不对,SDA和SCA管角总被拉底,救大家帮帮忙,我的邮箱是caosongyz126.com
答 1:
怎么没有人回答呢,我真的是好急呀
答 2:
#include <MSP430x14x.h>
#define SDA_1 P3OUT |= BIT3 /*SDA = 1*/
#define SDA_0 P3OUT &=~ BIT3 /*SDA = 0*/
#define SCL_1 P3OUT |= BIT2 /*SCL = 1*/
#define SCL_0 P3OUT &=~ BIT2 /*SCL = 0*/
#define DIR_IN P3DIR &=~ BIT3; SDA_1 /*I/O口为输入*/
#define DIR_OUT P3DIR |= BIT3 /*I/0口为输出*/
#define SDA_IN ((P3IN >> 3) & 0x01) /*Read SDA*/
unsigned int a[50];
static void Delay(unsigned int n)
unsigned int i;
for (i=0; i<5; i++)
void Init(void)
SCL_1;
Delay(5);
SDA_1;
Delay(5);
void Start(void)
SDA_1;
Delay(5);
SCL_1;
Delay(5);
SDA_0;
Delay(5);
SCL_0;
Delay(5);
void Stop(void)
SDA_0;
Delay(5);
SCL_1;
Delay(5);
SDA_1;
Delay(5);
void WriteByte(unsigned char WriteData)
unsigned char i;
for (i=0; i<8; i++)
SCL_0;
Delay(5);
if (((WriteData >> 7) & 0x01) == 0x01)
SDA_1;
else
SDA_0;
Delay(5);
SCL_1;
WriteData = WriteData << 1;
Delay(5);
SCL_0;
SDA_1;
Delay(5);
Delay(5);
unsigned char ReadByte(void)
unsigned char i;
unsigned char TempBit = 0;
unsigned char TempData = 0;
SCL_0;
Delay(5);
SDA_1;
for (i=0; i<8; i++)
Delay(5);
SCL_1;
Delay(5);
DIR_IN;
if (SDA_IN == 0x01 /*sda==1*/)
TempBit = 1;
else
TempBit = 0;
DIR_OUT;
TempData = (TempData << 1) | TempBit;
SCL_0;
Delay(5);
return(TempData);
void ReceiveAck(void)
unsigned char i = 0;
SCL_1;
Delay(5);
DIR_IN;
while ((SDA_IN == 0x01 /*sda==1*/) && (i < 255)/*调试方便,可以不要*/)
i++;
DIR_OUT;
SCL_0;
Delay(5);
void Acknowledge(void)
SCL_0;
Delay(5);
DIR_OUT;
SDA_0;
SCL_1;
Delay(5);
SCL_0;
unsigned int ReadWord(unsigned char unit/*address*/)
unsigned char HighData = 0;
unsigned char LowData = 0;
unsigned int TempData = 0;
Start();
WriteByte(0xa0);
ReceiveAck();
WriteByte(unit);
ReceiveAck();
Start();
WriteByte(0xa1);
ReceiveAck();
LowData = ReadByte();
Acknowledge();
HighData = ReadByte();
Stop();
TempData = (HighData << 8) + LowData;
Delay(1000);
return(TempData);
void ReadWords(unsigned char unit/*address*/)
unsigned char i;
Start();
WriteByte(0xa0);
ReceiveAck();
WriteByte(unit);
ReceiveAck();
Start();
WriteByte(0xa1);
ReceiveAck();
for (i=0; i<49; i++)
Acknowledge();
Acknowledge();
a[i]= (HighData << 8) + LowData;
Acknowledge();
Stop();
a[49] = (HighData << 8) + LowData;
Delay(1000);
void WriteWord(unsigned char unit/*address*/, unsigned int WriteData)
LowData = (unsigned char)WriteData;
HighData = (unsigned char)(WriteData >> 8);
Start();
WriteByte(0xa0);
ReceiveAck();
WriteByte(unit);
ReceiveAck();
WriteByte(LowData);
ReceiveAck();
WriteByte(HighData);
ReceiveAck();
Stop();
Delay(2000);
void main(void)
unsigned char i,j,miao,fen,shi;
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
P1DIR |= 0x01; // Set P1.2 to output direction
do{
DIR_OUT;//设SDA为输出
miao=ReadWord(0x02);
fen=ReadWord(0x03);
shi=ReadWord(0x04);
P1OUT ^= 0x01; // Toggle P1.0 using exclusive-OR
}while(1);
这是我的程序请高手指点
unsigned int a[50];
unsigned int i;
for (i=0; i<5; i++)
void Init(void)
SCL_1;
Delay(5);
SDA_1;
Delay(5);
void Start(void)
SDA_1;
Delay(5);
SCL_1;
Delay(5);
SDA_0;
Delay(5);
SCL_0;
Delay(5);
void Stop(void)
SDA_0;
Delay(5);
SCL_1;
Delay(5);
SDA_1;
Delay(5);
unsigned char i;
for (i=0; i<8; i++)
SCL_0;
Delay(5);
SDA_1;
else
SDA_0;
Delay(5);
SCL_1;
Delay(5);
SCL_0;
SDA_1;
Delay(5);
Delay(5);
unsigned char i;
SCL_0;
Delay(5);
SDA_1;
for (i=0; i<8; i++)
Delay(5);
SCL_1;
Delay(5);
DIR_IN;
TempBit = 1;
else
TempBit = 0;
DIR_OUT;
SCL_0;
Delay(5);
return(TempData);
SCL_1;
Delay(5);
DIR_IN;
i++;
DIR_OUT;
SCL_0;
Delay(5);
SCL_0;
Delay(5);
DIR_OUT;
SDA_0;
SCL_1;
Delay(5);
SCL_0;
Start();
WriteByte(0xa0);
ReceiveAck();
WriteByte(unit);
ReceiveAck();
Start();
WriteByte(0xa1);
ReceiveAck();
Acknowledge();
Stop();
Delay(1000);
return(TempData);
unsigned char i;
Start();
WriteByte(0xa0);
ReceiveAck();
WriteByte(unit);
ReceiveAck();
Start();
WriteByte(0xa1);
ReceiveAck();
Acknowledge();
Acknowledge();
Acknowledge();
Stop();
Delay(1000);
Start();
WriteByte(0xa0);
ReceiveAck();
WriteByte(unit);
ReceiveAck();
WriteByte(LowData);
ReceiveAck();
ReceiveAck();
Stop();
Delay(2000);
void main(void)
do{
DIR_OUT;//设SDA为输出
fen=ReadWord(0x03);
shi=ReadWord(0x04);
}while(1);
这是我的程序请高手指点
