74HC165 74HC165的操作,我到底错在哪里?太糊涂了
问
用PIC16F877A读74HC165来扩展做按键,时钟为外部10M。按键信号硬件上已经确认送到74HC165的A B C。。。H脚,有按键按下时输入给165的信号为低电平。程序如下:c165pl为165的SL/LOAD脚,c165ck为165的时钟脚,c165da为165的数据脚,c165pl_p为165的SL/LOAD脚所在的端口编号(如porta )
;read key information to kb_165_buf
c165_input_prg
;1)load 74HC165 data(pin state) to shift_register
bcf c165pl_p,c165pl
nop
bsf c165pl_p,c165pl
;2)serial output the shift_register
;the first shifted bit is "H(P7)" of 74HC165
movlw .8
movwf kb_input_bit_count
clrf kb_165_buf
c1_input_bit_loop
bcf c165ck_p,c165ck
nop
nop
bsf c165ck_p,c165ck
bcf status,c
btfsc c165da_p,c165da
bsf status,c
rrf kb_165_buf
decfsz kb_input_bit_count
goto c1_input_bit_loop
bcf c165ck_p,c165ck
bcf c165pl_p,c165pl
return
每次都只能正确读入接在H脚的按键信号,其他按键如接在A B C等脚,即使按下去了,都没有办法读回来,这到底是怎么回事?请大家帮忙分析一下。谢谢!
答 1: 晕倒,是LAYOUT工程师把CLOCK和DATA脚调了过来。
c165_input_prg
bcf c165pl_p,c165pl
nop
bsf c165pl_p,c165pl
movlw .8
clrf kb_165_buf
c1_input_bit_loop
bcf c165ck_p,c165ck
nop
nop
bsf c165ck_p,c165ck
bcf status,c
bsf status,c
rrf kb_165_buf
bcf c165ck_p,c165ck
bcf c165pl_p,c165pl
return
