430c 【求助】关于430c 的中断服务程序问题
问
刚开始学习430,写了如下中断程序:
interrupt[BASICTIMER_VECTOR] void basic_timer (void)
second++;
IFG2=BTIFG^0X80; //clear the interrupt flag
在进行编译的时候,有如下错误:
Error[Pe094]: the size of an array must be greater than zero
Error[Pe077]: this declaration has no storage class or type specifier
Error[Pe065]: expected a ";"
请问高手这是什么原因,难道是我的编译器不支持中断么?
在解决error[pe077]这个错误时,只要在interrupt前面增加static关键词就可以了,但是为什么不可以省略?
请各位高手指点。 答 1: 不同版本的中断书写格式是不一样的,请参考安装目录下的例程的书写格式。 答 2: 谢谢hzyhy得指点,我参考安装目录下的例程书写格式书写之后,上述的几个错误提示消失,但又出现了如下的错误提示:
Building configuration: t3 - Debug
display.c
icc430.exe -I C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\INC\ -I C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\INC\CLIB\ -o D:\
porgram of 430\430\Debug\Obj\ -z2 --no_cse --no_unroll --no_inline --no_code_motion --debug -e --double=32 D:\porgram of 430\430\display.c
IAR MSP430 C Compiler V2.21B-P1/W32 [Kickstart]
Copyright 1996-2003 IAR Systems. All rights reserved.
424 bytes of CODE memory
22 bytes of CONST memory
26 bytes of DATA memory (+ 9 bytes shared)
Errors: none
Warnings: none
Linking
xlink.exe D:\porgram of 430\430\Debug\Obj\display.r43 -o D:\porgram of 430\430\Debug\Exe\t3.d43 -rt -IC:\Program Files\IAR Systems\Embedded Workbench 3.2\430\
LIB\ -f C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\config\lnk430F449.xcl -e_small_write=_formatted_write -e_medium_read=_formatted_read -f C:\
Program Files\IAR Systems\Embedded Workbench 3.2\430\config\multiplier.xcl -f C:\Program Files\IAR Systems\Embedded Workbench 3.2\430\config\
compactmath.xcl
IAR Universal Linker V4.56E/386
Copyright 1987-2003 IAR Systems. All rights reserved.
Error[e46]: Undefined external "?SwitchKey16" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?Epilogue4" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?Epilogue3" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?DivMod16u" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?DivMod16s" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?cstart_init_copy" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?cstart_init_zero" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?longjmp_r4" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?longjmp_r5" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?setjmp_r4" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
Error[e46]: Undefined external "?setjmp_r5" referred in display ( D:\porgram of 430\430\Debug\Obj\display.r43 )
58 bytes of CODE memory
6 bytes of DATA memory (+ 9 absolute )
Errors: 11
Warnings: none
Total number of errors: 11
Total number of warnings: 0
上述错误提示应该都在LINKING的时候发生的情况,不明白这是为什么,敬请高手们再指点指点
second++;
在进行编译的时候,有如下错误:
display.c
Errors: none
Warnings: none
Linking
compactmath.xcl
Errors: 11
Warnings: none
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
| OK1126B-S开发板的脚本编程及应用设计被打赏¥27元 | |
| 5v升压8.4v两节锂电池充电芯片,针对同步和异步的IC测试被打赏¥35元 | |
| 【S32K3XX】S32DS LPI2C 配置失败问题解决被打赏¥22元 | |
| 【S32K3XX】FLASH 的 DID 保护机制被打赏¥19元 | |
| OK1126B-S开发板串口通信及其使用被打赏¥18元 | |
| 【S32K3XX】多核 CORE ID 获取被打赏¥18元 | |
| OK1126B-S开发板的GPIO资源及其使用被打赏¥20元 | |
| 【分享开发笔记,赚取电动螺丝刀】三分钟快速上手驱动屏幕(Arduino IDE环境)被打赏¥23元 | |
