SMCLK 定时器A使用SMCLK时钟源的问题!
问
我用以下程序监控P5.4,用示波器观察,频率确实为8MHZ(XT2上已接8MHZ晶振),但加上中间定时器A的程序,想用P1.1输出方波(即程序中间注释部分),P5.4频率变为750K左右,回到了默认DCO频率。而且P1.1并没有输出方波。请问各位大侠,帮个忙,谢谢!!
void main(void)
unsigned int i;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P5DIR |= 0x10; // P5.4 output direction
P5SEL |= 0x10; // P5.4 = MCLK option select
BCSCTL1 &= ~XT2OFF; // XT2 = HF XTAL
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG) != 0); // OSCFault flag still set?
BCSCTL2 |= SELM1+SELS; // SMCLK=MCLK = XT2 (safe)
/* TACTL = TASSEL1+TACLR ; // SMCLK, clear TAR, interrupt enabled
CCTL0 = OUTMOD_4 ; // CCR0 toggle, interrupt enabled
CCR0 = 1000-1;
P1SEL |= 0x02; // P1.1 option select
P1DIR |= 0x02; // P1.1 outputs
TACTL |= MC0; // Start Timer_A in continuous mode*/
for (;;); // Do nothing
} 答 1: 没有中断?
void main(void)
unsigned int i;
do
CCR0 = 1000-1;
} 答 1: 没有中断?
