电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » 45DB,FLASH,430 请求朋友帮忙啊 麻烦给个完整的 45DB FLAS
45DB,FLASH,430 请求朋友帮忙啊 麻烦给个完整的 45DB FLASH 的430读写程序
2006-09-17 18:14:16     打赏
关键词: FLASH     请求     朋友     帮忙     麻烦     完整     读写     程
2006-12-22 22:43:00     打赏
问 请求朋友帮忙啊 麻烦给个完整的 45DB FLASH 的430读写程序
非常的感谢 答 1: #include <msp430x44x.h>
char value; // 8-bit value to write to segment A
// Function prototypes
void write_SegA (char value);
void copy_A2B (void);
void main(void)
WDTCTL = WDTPW + WDTHOLD; // Stop watchdog timer
FCTL2 = FWKEY + FSSEL0 + FN0; // MCLK/2 for Flash Timing Generator
value = 0; // initialize value
while(1) // Repeat forever
write_SegA(value++); // Write segment A, increment value
copy_A2B(); // Copy segment A to B
char *Flash_ptr; // Flash pointer
unsigned int i;
Flash_ptr = (char *) 0x1080; // Initialize Flash pointer
FCTL1 = FWKEY + ERASE; // Set Erase bit
FCTL3 = FWKEY; // Clear Lock bit
*Flash_ptr = 0; // Dummy write to erase Flash segment
FCTL1 = FWKEY + WRT; // Set WRT bit for write operation
for (i=0; i<128; i++)
*Flash_ptr++ = value; // Write value to flash
FCTL1 = FWKEY; // Clear WRT bit
FCTL3 = FWKEY + LOCK; // Reset LOCK bit
char *Flash_ptrA; // Segment A pointer
char *Flash_ptrB; // Segment B pointer
unsigned int i;
Flash_ptrA = (char *) 0x1080; // Initialize Flash segment A pointer
Flash_ptrB = (char *) 0x1000; // Initialize Flash segment B pointer
*Flash_ptrB = 0; // Dummy write to erase Flash segment B
*Flash_ptrB++ = *Flash_ptrA++; // copy value segment A to segment B
} 答 2: ???
at45db
我也在找 答 3: #include "msp430x44x.h"
// MSP430F449
// /|\| XIN|-
// --|RST XOUT|- ________
// | P6.0|-->| A |
// | P6.1| . | T |
// | P6.2| . | 4 |
// | P6.3| . | 5 |
// | P6.4| . | D |
// | P6.5| . | B |
// | P6.6|-->| 0 |
// | | | 4 |
// | | | 1 |
// |________|
// Built with IAR Embedded Workbench Version: 1.26B
int word;
int cmd_word;
int R_word;
int tab[16]={0x21,0x22,0x23,0x24,0x25,0x26};
int *Ram_addr;
int *Buff_addr;
void Send_Byte(void)
int i;
int Tamp;
for (i=0;i<8;i++)
P6OUT &= 0xDF;
Tamp = word;
Tamp &= 0x80;
if(!Tamp)
P6OUT &= 0xEF;
else
P6OUT |= 0x10;
P6OUT |= 0x20;
word = word << 1;
void Send_Start(void)
P6DIR |= 0X30;
P6OUT |= 0X20;
word = cmd_word;
Send_Byte();
void Stop(void)
P6DIR &= 0X00;
P6DIR |= 0X63;
P6OUT |= 0X63;
void Flash_B_Write(void)
int j;
P6DIR |= 0X40;
P6OUT &= 0XBF;
cmd_word = 0x84;
Send_Start();
word = 0x00;
Send_Byte();
word = 0x00;
Send_Byte();
word = 0x1A;
Send_Byte();
for(j=0;j<16;j++)
word = tab[j];
Send_Byte();
Buff_addr = (int *)0x1A;
Stop();
void Receive_Byte(void)
int i;
P6DIR |= 0X20;
P6DIR &= 0XF7;
R_word = 0x00;
P6OUT &= 0xBF;
for(i=0;i<8;i++)
P6OUT &= 0xDF;
P6OUT |= 0X20;
if(P6IN & 0x08)
R_word |= 0x01;
else
R_word &= 0xFE;
P6OUT &= 0xDF;
R_word = R_word << 1;
R_word = R_word >> 1;
void Flash_B_Read(void)
int j;
P6DIR |= 0X40;//CS out
P6OUT &= 0XBF;
cmd_word = 0x54;
Send_Start();
word = 0x00;
Send_Byte();
word = 0x00;
Send_Byte();
word = 0x1A;
Send_Byte();
word = 0xff;
Send_Byte();
for(j=0;j<16;j++)
Receive_Byte();
*Ram_addr++ = R_word;
Stop();
void main(void)
while(1){
int m = 0x7fff;
FLL_CTL1 = SELM_A + FLL_DIV_8;
P6DIR &= 0X00;
P6SEL &= 0X00;
P6DIR |= 0X63;
P6OUT |= 0X63;
Flash_B_Write();
while(m-- > 0);
Ram_addr = (int *)0x270;
Flash_B_Read();
