msp430,lpm3,demo,lpm3 以下是msp430的lpm3的demo程序,我只改了延时的长度。为何程序一直没法从lpm3模式中出来!急呀
问
#include "MSP430x11x.h"
ORG 0FC00h ; Program Start cpu=MSP430f1101
RESET mov.w #300h,SP ; Initialize stackpointer
SetupBC bis.b #DIVA1,&BCSCTL1 ; ACLK/4
SetupWDT mov.w #WDT_ADLY_1000,&WDTCTL ; WDT 1s*4 interval timer
bis.b #WDTIE,&IE1 ; Enable WDT interrupt
SetupP1 mov.b #0FFh,&P1DIR ; All P1.x outputs
clr.b &P1OUT ; All P1.x reset
SetupP2 mov.b #0FFh,&P2DIR ; All P2.x outputs
clr.b &P2OUT ; All P2.x reset
eint ; Enable interrupts
Mainloop bis.w #GIE+CPUOFF+SCG1+SCG0,SR ; Enter LPM3
bis.b #001h,&P1OUT ; Set P1.0
push.w #20000 ; Delay to TOS
Delay dec.w 0(SP) ; Decrement TOS
jnz Delay ; Delay over?
incd.w SP ; Clean stack
bic.b #001h,&P1OUT ; Reset P1.0
jmp Mainloop ; Again
WDT_ISR; Exit all LPMx modes, reti returns system active with GIE enabled
bic.w #CPUOFF+SCG1+SCG0,0(SP) ; System active on TOS
reti ;
; Interrupt Vectors Used MSP430x11x1
ORG 0FFFEh ; MSP430 RESET Vector
DW RESET ;
ORG 0FFF4h ; WDT Vector
DW WDT_ISR ;
END 答 1: 可以啊。
reti ;
DW RESET ;
DW WDT_ISR ;
END 答 1: 可以啊。
