电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » TimerA 请问刘工哪里有“用TimerA实现串口通讯”的c语言例程
2006-09-17 18:14:16     打赏
关键词: TimerA     请问     刘工     哪里     实现     串口     通讯
2006-12-22 22:43:00     打赏
问 请问刘工哪里有“用TimerA实现串口通讯”的c语言例程 答 1: 发一个通用的I/O模拟串口程序(适用于任何带有定时器的单片机)
// UART.C
// Generic software uart written in C, requiring a timer set to 3 times
// the baud rate, and two software read/write pins for the receive and
// transmit functions.
// * Received characters are buffered
// * putchar(), getchar(), kbhit() and flush_input_buffer() are available
// * There is a facility for background processing while waiting for input
// Colin Gittins, Software Engineer, Halliburton Energy Services
// The baud rate CAN be configured by changing the BAUD_RATE macro as
// follows:
// #define BAUD_RATE 19200.0
// The function init_uart() must be called before any comms CAN take place
// Interface routines required:
// 1. get_rx_pin_status()
// Returns 0 or 1 dependent on whether the receive pin is high or low.
// 2. set_tx_pin_high()
// Sets the transmit pin to the high state.
// 3. set_tx_pin_low()
// Sets the transmit pin to the low state.
// 4. idle()
// Background functions to execute while waiting for input.
// 5. timer_set( BAUD_RATE )
// Sets the timer to 3 times the baud rate.
// 6. set_timer_interrupt( timer_isr )
// Enables the timer interrupt.
// Functions provided:
// 1. void flush_input_buffer( void )
// Clears the contents of the input buffer.
// 2. char kbhit( void )
// Tests whether an input character has been received.
// 3. char getchar( void )
// Reads a character from the input buffer, waiting if necessary.
// 4. void turn_rx_on( void )
// Turns on the receive function.
// 5. void turn_rx_off( void )
// Turns off the receive function.
// 6. void putchar( char )
// Writes a character to the serial port.
#include <stdio.h>
#define IN_BUF_SIZE 256
#define TRUE 1
#define FALSE 0
static unsigned char inbuf[IN_BUF_SIZE];
static unsigned char qin = 0;
static unsigned char qout = 0;
static char flag_rx_waiting_for_stop_bit;
static char flag_rx_off;
static char rx_mask;
static char flag_rx_ready;
static char flag_tx_ready;
static char timer_rx_ctr;
static char timer_tx_ctr;
static char bits_left_in_rx;
static char bits_left_in_tx;
static char rx_num_of_bits;
static char tx_num_of_bits;
static char internal_rx_buffer;
static char internal_tx_buffer;
static char user_tx_buffer;
void timer_isr(void)
char mask, start_bit, flag_in;
// Transmitter Section
if ( flag_tx_ready )
if ( --timer_tx_ctr<=0 )
mask = internal_tx_buffer&1;
internal_tx_buffer >>= 1;
if ( mask )
set_tx_pin_high();
else
set_tx_pin_low();
timer_tx_ctr = 3;
if ( --bits_left_in_tx<=0 )
flag_tx_ready = FALSE;
// Receiver Section
if ( flag_rx_off==FALSE )
if ( flag_rx_waiting_for_stop_bit )
if ( --timer_rx_ctr<=0 )
flag_rx_waiting_for_stop_bit = FALSE;
flag_rx_ready = FALSE;
internal_rx_buffer &= 0xFF;
if ( internal_rx_buffer!=0xC2 )
inbuf[qin] =
internal_rx_buffer;
if ( ++qin>=IN_BUF_SIZE )
qin = 0;
else // rx_test_busy
if ( flag_rx_ready==FALSE )
start_bit = get_rx_pin_status();
// Test for Start Bit
if ( start_bit==0 )
flag_rx_ready = TRUE;
internal_rx_buffer = 0;
timer_rx_ctr = 4;
bits_left_in_rx =
rx_num_of_bits;
rx_mask = 1;
else // rx_busy
// rcv
timer_rx_ctr = 3;
flag_in =
if ( flag_in )
internal_rx_buffer |= rx_mask;
rx_mask <<= 1;
if ( --
bits_left_in_rx<=0 )
flag_rx_waiting_for_stop_bit = TRUE;
void init_uart( void )
flag_rx_off = FALSE;
rx_num_of_bits = 10;
tx_num_of_bits = 10;
set_tx_pin_low();
timer_set( BAUD_RATE );
set_timer_interrupt( timer_isr ); // Enable timer interrupt
char _getchar( void )
char ch;
do
while ( qout==qin )
idle();
ch = inbuf[qout] & 0xFF;
if ( ++qout>=IN_BUF_SIZE )
qout = 0;
while ( ch==0x0A || ch==0xC2 );
return( ch );
void _putchar( char ch )
while ( flag_tx_ready );
user_tx_buffer = ch;
// invoke_UART_transmit
timer_tx_ctr = 3;
bits_left_in_tx = tx_num_of_bits;
internal_tx_buffer = (user_tx_buffer<<1) | 0x200;
flag_tx_ready = TRUE;
qin = 0;
qout = 0;
char kbhit( void )
return( qin!=qout );
flag_rx_off = TRUE;
