问
Error[e16]: Segment INTVEC (size: 0x20 align: 0x1) is too long for segment definition. At least 0xc more bytes needed. The problem occurred while processing the segment placement command "-Z(CODE)INTVEC=FFE0-FFFF", where at the moment of placement the available memory ranges were "ffec-ffff"
Total number of errors: 1
Total number of warnings: 0 答 1: 定义的空间超出了 答 2: 是汇编~~~还是C~~如果是汇编~~在XLINK的INCLUDE选项中把~~Ingnore CSTARTUP In LIBRARY ~~打上勾~~~如果是C~~请选择正确的XCL文件~~ 答 3: 这个问题我搞了一个下午,实在没办法,到这里来看看,终于解决了。太谢谢了。 答 4: 我用的iar是win ver 1.26版本找不到" 汇编~~在XLINK的INCLUDE选项中把~~Ingnore CSTARTUP In LIBRARY ~~打上勾"?该如何办?
