大家帮忙看看,这是怎会事???
问
我遇到编译出错,显示如下信息:
Error[e16]: Segment CODE (size: 0x496 align: 0x1) is too long for segment definition. At least 0xb6 more bytes needed. The problem occurred while processing the segment placement command "-Z(CODE)CODE,CONST,CSTR,CDATA0,CCSTR=FC00-FFDF", where at the moment of placement the available memory ranges were "fc00-ffdf"
请问这是啥问题???? :face11: 答 1: 看看以前的贴子! 答 2: 引用: 答 3: 引用: 答 4: 资源不够,你用的哪款? 答 5: 我用的是MSP430F1101.
