2407,AD 高手请帮我看看2407 自带AD采值程序的问题
问
我现在用2407的自带AD采值
思路是利用Timer1的周期中断,产生AD启动标志
现在的问题是 采值移位后都是108左右(十进制)
好像AD没有工作 真是奇怪
请看看程序 提意见
谢谢!
/* test.c */
#include "C2407.h"
volatile unsigned int *Pointer_AD;
unsigned int SampleAverage_ADvalue=0;
unsigned int Sample_Max=0;
unsigned int Sample_Min=0;
unsigned int First_Flag=0;
unsigned int start_ADC=0;
void disable()
asm(" setc INTM");
void enable()
asm(" clrc INTM");
void Sys_Init()
asm(" clrc SXM");
asm(" clrc OVM");
asm(" clrc CNF");
SCSR1=0x86FF; /* system clcock is 10M */
WDCR=0x00E8;
IMR=0x0002; /* time 1 period interrupt */
IFR=0xFFFF;
WSGR=0x0000;
First_Flag=0;
void Delay(unsigned int x)
unsigned int i,j;
for(i=0;i<x;i++)
for(j=0;j<5;j++)
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
void ADC_TIMER1_Init()
/* EVA Timer 1 period IFR 1ms */
EVAIMRA |=0x0080;
EVAIFRA = 0xFFFF; /* */
T1CON=0x160C;
T1PER=0x061A;
T1CNT=0x0000;
GPTCONA = 0x0000; /* EVA Timer 1 enable ADC */
/*************** ADC ********/
ADCTRL1 = 0x4000; /* reset ADC module */
asm(" nop");
ADCTRL1 = 0x3010; /* configure ADCTRL1 register */
asm(" nop");
ADCTRL2 = 0x4200;
asm(" nop");
ADCTRL2 = 0x2000;
asm(" nop");
MAXCONV = 0x0000;
asm(" nop");
CHSELSEQ1 = 0x0000;
asm(" nop");
Delay(1000);
void ADC_Enable()
T1CON |=0x0040;
interrupt void INT2_ISR(void)
if(PIVR==0x0027)
start_ADC=1;
T1CNT=0x0000;
EVAIFRA =0xFFFF;
ADCTRL2 |= 0x2000; /* set SOC_SEQ1 bit to start ADC */
enable();
void interrupt nothing()
enable();
return;
main()
disable();
Sys_Init();
ADC_TIMER1_Init();
enable();
ADC_Enable();
while(1)
asm(" nop" );
if(start_ADC==1)
asm(" nop" );
ADCTRL2 |= 0x2000;
asm(" nop" );
asm(" nop" );
asm(" nop" );
while(ADCTRL2 &0x1000);
Pointer_AD=&RESULT0;
asm(" nop" );
asm(" nop" );
asm(" nop" );
SampleAverage_ADvalue=*Pointer_AD>>6;
asm(" nop" );
asm(" nop" );
asm(" nop" );
if(First_Flag==0) {Sample_Max=Sample_Min=SampleAverage_ADvalue; First_Flag=1;}
if(SampleAverage_ADvalue>=Sample_Max) Sample_Max=SampleAverage_ADvalue;
if(SampleAverage_ADvalue<Sample_Min) Sample_Min=SampleAverage_ADvalue;
ADCTRL2 |= 0x4000; /* conv00 */
start_ADC=0;
.title "vectors.asm"
.ref _c_int0,_nothing,_INT2_ISR
.sect ".vectors"
reset: b _c_int0
int1: b _nothing
int2: b _INT2_ISR
int3: b _nothing
int4: b _nothing
int5: b _nothing
int6: b _nothing
reserved: b _nothing
sw_int8: b _nothing
sw_int9: b _nothing
sw_int10: b _nothing
sw_int11: b _nothing
sw_int12: b _nothing
sw_int13: b _nothing
sw_int14: b _nothing
sw_int15: b _nothing
sw_int16: b _nothing
trap: b _nothing
nmint: b _nothing
emu_trap: b _nothing
sw_int20: b _nothing
sw_int21: b _nothing
sw_int22: b _nothing
sw_int23: b _nothing
答 1: 上述程序的更正:我现在用2407的自带AD采值
好像AD没有工作 真是奇怪
请看看程序 提意见
谢谢!
/* test.c */
#include "C2407.h"
void disable()
asm(" setc INTM");
void enable()
asm(" clrc INTM");
void Sys_Init()
asm(" clrc SXM");
asm(" clrc OVM");
asm(" clrc CNF");
WDCR=0x00E8;
IFR=0xFFFF;
WSGR=0x0000;
First_Flag=0;
unsigned int i,j;
for(i=0;i<x;i++)
for(j=0;j<5;j++)
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
EVAIMRA |=0x0080;
T1CON=0x160C;
T1PER=0x061A;
T1CNT=0x0000;
GPTCONA = 0x0000; /* */
asm(" nop");
asm(" nop");
ADCTRL2 = 0x4200;
asm(" nop");
ADCTRL2 = 0x2000;
asm(" nop");
MAXCONV = 0x0000;
asm(" nop");
CHSELSEQ1 = 0x0000;
asm(" nop");
Delay(1000);
void ADC_Enable()
T1CON |=0x0040;
if(PIVR==0x0027)
start_ADC=1;
T1CNT=0x0000;
EVAIFRA =0xFFFF;
enable();
enable();
return;
main()
disable();
Sys_Init();
ADC_TIMER1_Init();
enable();
ADC_Enable();
while(1)
asm(" nop" );
if(start_ADC==1)
asm(" nop" );
ADCTRL2 |= 0x2000;
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
start_ADC=0;
.sect ".vectors"
reset: b _c_int0
int1: b _nothing
int2: b _INT2_ISR
int3: b _nothing
int4: b _nothing
int5: b _nothing
int6: b _nothing
sw_int8: b _nothing
sw_int9: b _nothing
trap: b _nothing
nmint: b _nothing
好像AD没有工作 真是奇怪
请看看程序 提意见
谢谢!
/* test.c */
#include "C2407.h"
void disable()
asm(" setc INTM");
void enable()
asm(" clrc INTM");
void Sys_Init()
asm(" clrc SXM");
asm(" clrc OVM");
asm(" clrc CNF");
WDCR=0x00E8;
IFR=0xFFFF;
WSGR=0x0000;
First_Flag=0;
unsigned int i,j;
for(i=0;i<x;i++)
for(j=0;j<5;j++)
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
EVAIMRA |=0x0080;
T1CON=0x160C;
T1PER=0x061A;
T1CNT=0x0000;
asm(" nop");
asm(" nop");
ADCTRL2 = 0x4200;
asm(" nop");
ADCTRL2 = 0x2000;
asm(" nop");
MAXCONV = 0x0000;
asm(" nop");
CHSELSEQ1 = 0x0000;
asm(" nop");
Delay(1000);
void ADC_Enable()
T1CON |=0x0040;
if(PIVR==0x0027)
start_ADC=1;
T1CNT=0x0000;
EVAIFRA =0xFFFF;
enable();
enable();
return;
main()
disable();
Sys_Init();
ADC_TIMER1_Init();
enable();
ADC_Enable();
while(1)
asm(" nop" );
if(start_ADC==1)
asm(" nop" );
ADCTRL2 |= 0x2000;
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
start_ADC=0;
.sect ".vectors"
reset: b _c_int0
int1: b _nothing
int2: b _INT2_ISR
int3: b _nothing
int4: b _nothing
int5: b _nothing
int6: b _nothing
sw_int8: b _nothing
sw_int9: b _nothing
trap: b _nothing
nmint: b _nothing
好像AD没有工作 真是奇怪
请看看程序 提意见
谢谢!
/* test.c */
#include "C2407.h"
void disable()
asm(" setc INTM");
void enable()
asm(" clrc INTM");
void Sys_Init()
asm(" clrc SXM");
asm(" clrc OVM");
asm(" clrc CNF");
WDCR=0x00E8;
IFR=0xFFFF;
WSGR=0x0000;
First_Flag=0;
unsigned int i,j;
for(i=0;i<x;i++)
for(j=0;j<5;j++)
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
asm(" nop");
EVAIMRA |=0x0080;
T1CON=0x160C;
T1PER=0x061A;
T1CNT=0x0000;
asm(" nop");
asm(" nop");
ADCTRL2 = 0x4200;
asm(" nop");
ADCTRL2 = 0x2000;
asm(" nop");
MAXCONV = 0x0000;
asm(" nop");
CHSELSEQ1 = 0x0000;
asm(" nop");
Delay(1000);
void ADC_Enable()
T1CON |=0x0040;
if(PIVR==0x0027)
start_ADC=1;
T1CNT=0x0000;
EVAIFRA =0xFFFF;
enable();
enable();
return;
main()
disable();
Sys_Init();
ADC_TIMER1_Init();
enable();
ADC_Enable();
while(1)
asm(" nop" );
if(start_ADC==1)
asm(" nop" );
ADCTRL2 |= 0x2000;
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
asm(" nop" );
start_ADC=0;
.sect ".vectors"
reset: b _c_int0
int1: b _nothing
int2: b _INT2_ISR
int3: b _nothing
int4: b _nothing
int5: b _nothing
int6: b _nothing
sw_int8: b _nothing
sw_int9: b _nothing
trap: b _nothing
nmint: b _nothing
