VC5402 请教VC5402引导中程序跑飞的问题
问
typedef unsigned int u16;
#define PMST 0x001D
#define SWWSR 0x0028
#define SWCR 0x002B
#define BSCR 0x0029
#define CLKMD 0x0058
#define PMST_VAL 0x00A0 //interupt vectors from ox80
#define SWWSR_VAL 0x7fff
#define SWCR_VAL 0x0001
#define BSCR_VAL 0x0800
#define CLKMD_VAL 0xF007
/* initialize the board */
void init_board(void)
*(volatile u16 *)CLKMD=CLKMD_VAL; //initialize vc5402 clock
*(volatile u16 *)PMST=PMST_VAL;
*(volatile u16 *)SWWSR=SWWSR_VAL;
*(volatile u16 *)SWCR=SWCR_VAL;
*(volatile u16 *)BSCR=BSCR_VAL;
初始化的汇编如下:
0000:189F 4A11 PSHM 11h
0000:18A0 7711 STM 58h,11h
0000:18A2 7681 ST #4007h,*AR1
0000:18A4 7711 STM 1dh,11h
0000:18A6 7681 ST #0f007h,*AR1 ;
0000:18A8 7711 STM 28h,11h
0000:18AA 7681 ST #7fffh,*AR1
0000:18AC 7711 STM 2bh,11h
0000:18AE 7681 ST #1h,*AR1
0000:18B0 7711 STM 29h,11h
0000:18B2 7681 ST #800h,*AR1
0000:18B4 8A11 POPM 11h
0000:18B5 FC00 RET
这个地方程序总是跑飞,是不是要压栈AR1?在C语言中怎么办?谢谢哈 答 1: 试试你试试让程序最终进入死循环,看看还跑飞不? 答 2: haha我发现是初始化的问题,如果不初始化的话,程序就不会飞。当我又想初始化,怎么办? 答 3: 修改PLL后要加多几个NOP修改PLL后要加多几个NOP
#define PMST 0x001D
#define SWCR 0x002B
#define BSCR 0x0029
初始化的汇编如下:
0000:18B5 FC00 RET
