LED LED显示摇棒全套方案及源程序--读后感
问
// LED显示摇棒
// 作者:nim 于 http://www.21icbbs.com 2005-1-7
// email: linyige@yahoo.com
// 本设计版权归作者所有,请勿擅自用于商业目的,转载请注明作者及出处
#include <reg51.h>
#define SEG 17 //每帧图片分成17列来显示
#define INTERVAL 20 //每幅图片在左右摇摆20次后换下一幅
typedef unsigned char uchar;
typedef unsigned int uint;
code char pattern[17][3]={ //3幅图片的字模
{0xff,0xff,0xff},
{0xff,0xff,0xff},
{0xff,0xff,0xff},
{0xff,0x9f,0xff},
{0xff,0x6f,0xf9},
{0xff,0x77,0x65},
{0xfe,0xbb,0x1e},
{0x7e,0xdd,0xfe},
{0x00,0xee,0xfe},
{0x7e,0xdd,0xfe},
{0xfe,0xbb,0x1e},
{0xff,0x77,0x65},
{0xff,0x6f,0xf9},
{0xff,0x9f,0xff},
{0xff,0xff,0xff},
{0xff,0xff,0xff},
{0xff,0xff,0xff},
uchar phase,th1,tl1,index,count;
main()
EA=0;
EX0=1;
ET1=1;
PX0=1;
IT0=1;
TMOD=0x11;
index=0;
EA=1;
while(1)
void Int0_Handle(void) interrupt 0 using 2
uint t0_time;
TR0=0;
TR1=0;
TF1=0;
t0_time=TH0<<8|TL0;
TL0=0;
TH0=0;
TR0=1;
t0_time=65535-t0_time/SEG;
th1=t0_time/256;
TH1=th1;
tl1=t0_time % 256;
TL1=tl1;
if (count<3*INTERVAL){ //3幅图片循环
count++;
else{
count=0;
index=count/INTERVAL;
if (th1!=0xff || tl1!=0xff){ //如果摆动特别慢,定时器溢出就不显示
phase=0;
TR1=1;
else{
TR1=0;
void Timer1(void) interrupt 3 using 3
if (phase<SEG) //17段依次显示
P1=pattern[phase][index];
phase++;
TH1=th1;
TL1=tl1;
一直没弄明白如何用定时器0计算两次外部中断的间隔的摇摆时间的?
答 1: 顶!2051中的定时器/计数器0的初值如何赋值的,事先并不知道摇摆一次所需的时间啊!而timer/counter0工作必须先赋值进去(是由2051是步增的,溢出产生中断的)
// LED显示摇棒
#include <reg51.h>
{0xff,0xff,0xff},
{0xff,0xff,0xff},
{0xff,0xff,0xff},
{0xff,0x9f,0xff},
{0xff,0x6f,0xf9},
{0xff,0x77,0x65},
{0xfe,0xbb,0x1e},
{0x7e,0xdd,0xfe},
{0x00,0xee,0xfe},
{0x7e,0xdd,0xfe},
{0xfe,0xbb,0x1e},
{0xff,0x77,0x65},
{0xff,0x6f,0xf9},
{0xff,0x9f,0xff},
{0xff,0xff,0xff},
{0xff,0xff,0xff},
{0xff,0xff,0xff},
main()
EA=0;
EX0=1;
ET1=1;
PX0=1;
IT0=1;
TMOD=0x11;
index=0;
EA=1;
while(1)
uint t0_time;
TR0=0;
TR1=0;
TF1=0;
t0_time=TH0<<8|TL0;
TL0=0;
TH0=0;
TR0=1;
th1=t0_time/256;
TH1=th1;
tl1=t0_time % 256;
TL1=tl1;
count++;
else{
count=0;
phase=0;
TR1=1;
else{
TR1=0;
phase++;
TH1=th1;
TL1=tl1;
| OrangePiZero2W系统被打赏¥33元 | |
