C51 各位帮忙分析一下图中有书签处的C51源代码与反汇编为什么不对应?
问
//源代码
#include "at89x52.h"
#include "dtype.h"
#define CHIP_ERASE1 0x30
#define CHIP_ERASE2 0x30
#define ADRSF 0x00
#define NOSLT 0xFF
#define ADR377 P3_4
#define RED P3_2
#define GREEN P3_3
#define ON 0
#define OFF 1
* 名称: ChipErase *
* 描述: 擦除SST28SF040芯片 *
* 输入: 无 *
* 输出: 无 *
void ChipErase(void)
uchar xdata *p;
p = 0x0000;
P1 = ADRSF;
*p = CHIP_ERASE1;
P1 = NOSLT;
P1 = ADRSF;
*p = CHIP_ERASE2;
P1 = NOSLT;
* 名称: ChipNoProtection *
* 描述: SST28SF040芯片无保护 *
* 输入: 无 *
* 输出: 无 *
void ChipNoProtection()
uchar temp;
uchar xdata *p;
p = 0x0000;
ADR377 = 0;
*p = 0x00;
ADR377 = 1;
p = 0x1823;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x1820;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x1822;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x0418;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x041B;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x0419;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x041A;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
void main(void)
RD = ON;
P1 = NOSLT;
ChipNoProtection();
ChipErase();
RED = OFF;
GREEN = ON;
while(1);
} 答 1: 你的temp只读不用,编译器认为这些操作没必要,就把它优化掉了 答 2: 请问:应该如何修改.谢谢! 答 3: 变量申明加 volatile
答 4: 谢谢! 我试试 答 5: 好了,谢谢@! 答 6: 呵呵,论坛提问就该这样,1、问的时候讲清楚,能有多清楚就多清楚
2、关注自己的帖子,随时反馈进度
3、解决问题后说明一下,最好说明解决的方法
4、注意礼貌,不忘道谢
如果大家都能这样,你的问题一定能很快解决的,相信21IC的人气会更旺的!
呵呵:-)
答 7: 是啊,看这个贴的人都舒服.--我. 答 8: 谢谢各位!
#include "dtype.h"
#define ADRSF 0x00
#define NOSLT 0xFF
#define ADR377 P3_4
#define RED P3_2
#define GREEN P3_3
#define ON 0
#define OFF 1
* 名称: ChipErase *
* 输入: 无 *
* 输出: 无 *
uchar xdata *p;
p = 0x0000;
P1 = ADRSF;
*p = CHIP_ERASE1;
P1 = NOSLT;
P1 = ADRSF;
*p = CHIP_ERASE2;
P1 = NOSLT;
* 输入: 无 *
* 输出: 无 *
uchar temp;
uchar xdata *p;
p = 0x0000;
ADR377 = 0;
*p = 0x00;
ADR377 = 1;
p = 0x1823;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x1820;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x1822;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x0418;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x041B;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x0419;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
p = 0x041A;
P1 = ADRSF;
temp = *p;
P1 = NOSLT;
void main(void)
RD = ON;
P1 = NOSLT;
ChipNoProtection();
ChipErase();
RED = OFF;
GREEN = ON;
while(1);
2、关注自己的帖子,随时反馈进度
4、注意礼貌,不忘道谢
呵呵:-)
