问
我将程序下载到目标板后,然后设置breakpoint, 但是不管将breakpoint设置在那个位置,总是不对,出现这样的提示:
Breakpoint Manager: Unable to move breakpoint to a valid line at source line: main.C line 64
It has been disabled.
Breakpoint Manager: Some breakpoints are not at valid lines.
Code Composer has moved these breakpoints to the next valid line.
请高手帮帮忙呀 答 1: 已经解决已经解决 答 2: 怎么解决的?说说吧 答 3: rehow? 答 4: 我改变了“Build Option"我改变了“Build Option"
| OrangePiZero2W系统被打赏¥33元 | |
