max3100,c51 那位兄台用过max3100 c51的驱动有吗,发我一个
问
答 1:
贴一个#define uchar unsigned char
#define uint unsigned int
#define FOSC 11059200ul
#define BAUD 9600
#define SMODX 0
#define TH1_VAL (256 - (uchar)(FOSC * (1<<SMODX) * 1.0 / 384 / BAUD))
#define TL1_VAL TH1_VAL
sbit DIN =P1^3;
sbit DOUT =P1^2;
sbit SCLK =P1^1;
sbit CS =P1^0;
void Delayus(uchar t)
for(; t>0; t--)
uchar Byte3100(uchar dat) reentrant
uchar i;
DOUT = 1;
DIN = 1;
for(i=0; i<8; i++)
if(dat & 0x80)
DIN = 1;
else
DIN = 0;
SCLK = 1;
dat <<= 1;
dat |= DOUT;
SCLK = 0;
return dat;
uchar Send3100(uchar tx1,uchar tx2) reentrant
CS = 0;
Byte3100(tx1);
tx1 = Byte3100(tx2);
CS = 1;
return tx1;
void Init3100(void)
uchar dat,i=0;
do
Send3100(0xc4,0x0a); //0b:4800,0a:9600
Delayus(200);
dat = Send3100(0x40,0x00);
}while((dat!= 0x01)&&(++i<5));
Send3100(0x84,0x00);
Delayus(200);
答 2: 可用模拟的,网上的一个短距离能跑到19200,11.0592M晶振 答 3: SC16IS752多好的东西!
#define BAUD 9600
#define SMODX 0
sbit DIN =P1^3;
sbit DOUT =P1^2;
sbit SCLK =P1^1;
sbit CS =P1^0;
for(; t>0; t--)
uchar i;
DOUT = 1;
DIN = 1;
for(i=0; i<8; i++)
if(dat & 0x80)
DIN = 1;
else
DIN = 0;
SCLK = 1;
dat <<= 1;
dat |= DOUT;
SCLK = 0;
return dat;
CS = 0;
Byte3100(tx1);
CS = 1;
return tx1;
void Init3100(void)
uchar dat,i=0;
do
Delayus(200);
Delayus(200);
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
