ㄐ偶际?485 求教高手,485通讯,我是菜鸟 急需!!
问
我做一个把4-20ma采集电路,然后通过485借口发送出去,原理如下图。信号经485赚232接头送pc 显示,我用的是串口调试助手V2.1,不过没现实,求教高手!!!
程序:
org 000h
ljmp strat
org 0100h
strat:
mov tmod,#20h
mov th1, #0fdh
mov tl1, #0fdh
MOV PCON,#00H
setb EA
CLR ET1
SETB ES
SETB TR1
MOV SCON ,#50H
mm:
lcall read
SJMP mm
READ:
CLR P1.2
NOP
SETB P1.0
MOV R0,#08H
MOV A,#00H
LCALL AD
MOV R2,A
MOV A,#00H
MOV R0,#02H
LCALL AD
MOV R3,A
SETB P1.2
SEND1:
MOV A,R3
MOV SBUF,A
WAIT1:
JBC TI,SEND2
SJMP WAIT1
SEND2:
MOV A,R2
MOV SBUF,A
WAIT2:
JBC T1,DELAY
SJMP WAIT2
DELAY:
MOV R4,#200
D50MS:MOV R5,#250
DJNZ R5,$
DJNZ R4,D50MS
RET
AD:
RL A
CLR P1.0
NOP
MOV C,P1.1
MOV ACC.0,C
SETB P1.0
DJNZ R0,AD
RET
END
答 1: 你的485既允许接收也允许发送怎么能好使呢把RE\DE连在一起连接到单片机IO上控制收发 答 2: 谢谢,squarelook这个 我改了我re/de都接到+5v上,还是不行 答 3: 接到单片机的一个引脚上低收高发
程序:
org 000h
ljmp strat
org 0100h
strat:
mov tmod,#20h
mov th1, #0fdh
mov tl1, #0fdh
MOV PCON,#00H
setb EA
CLR ET1
SETB ES
SETB TR1
MOV SCON ,#50H
mm:
lcall read
SJMP mm
READ:
CLR P1.2
NOP
SETB P1.0
MOV R0,#08H
MOV A,#00H
LCALL AD
MOV R2,A
MOV A,#00H
MOV R0,#02H
LCALL AD
MOV R3,A
SETB P1.2
SEND1:
MOV A,R3
MOV SBUF,A
WAIT1:
JBC TI,SEND2
SJMP WAIT1
SEND2:
MOV A,R2
MOV SBUF,A
WAIT2:
JBC T1,DELAY
SJMP WAIT2
DELAY:
MOV R4,#200
D50MS:MOV R5,#250
DJNZ R5,$
DJNZ R4,D50MS
RET
AD:
RL A
CLR P1.0
NOP
MOV C,P1.1
MOV ACC.0,C
SETB P1.0
DJNZ R0,AD
RET
END
| OrangePiZero2W系统被打赏¥33元 | |
