DX,IO 各位DX,能否贴几个IO口模拟串口的c语言程序啊
问
谢谢!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
答 1:
可以到我这里来看看http://www.glorywork.com
答 2:
在网上找了一个,就是不知道MODE_QUICK什么意思?因为不知道MODE_QUICK是什么意思?所以还是用不了
#include <reg51.h>
sbit BT_SND =P1^0;
sbit BT_REC =P1^1;
IO 口模拟232通讯程序
使用两种方式的C程序 占用定时器0
#define MODE_QUICK
#define F_TM F0
#define TIMER0_ENABLE TL0=TH0; TR0=1;
#define TIMER0_DISABLE TR0=0;
sbit ACC0= ACC^0;
sbit ACC1= ACC^1;
sbit ACC2= ACC^2;
sbit ACC3= ACC^3;
sbit ACC4= ACC^4;
sbit ACC5= ACC^5;
sbit ACC6= ACC^6;
sbit ACC7= ACC^7;
void IntTimer0() interrupt 1
F_TM=1;
//发送一个字符
void PSendChar(unsigned char inch)
#ifdef MODE_QUICK
ACC=inch;
F_TM=0;
BT_SND=0; //start bit
TIMER0_ENABLE; //启动
//先送出低位
while(!F_TM); BT_SND=ACC0; F_TM=0;
while(!F_TM); BT_SND=ACC1; F_TM=0;
while(!F_TM); BT_SND=ACC2; F_TM=0;
while(!F_TM); BT_SND=ACC3; F_TM=0;
while(!F_TM); BT_SND=ACC4; F_TM=0;
while(!F_TM); BT_SND=ACC5; F_TM=0;
while(!F_TM); BT_SND=ACC6; F_TM=0;
while(!F_TM); BT_SND=ACC7; F_TM=0;
while(!F_TM); BT_SND=1; F_TM=0;
while(!F_TM);
TIMER0_DISABLE; //停止timer
#else
unsigned char ii;
ii=0;
F_TM=0;
TIMER0_ENABLE; //启动
while(!F_TM);
while(ii<8)
if(inch&1)
{ BT_SND=1; }
else
{ BT_SND=0; }
F_TM=0;
while(!F_TM);ii++;
inch>>=1;
BT_SND=1;
F_TM=0;
while(!F_TM);
#endif
//接收一个字符
unsigned char PGetChar()
#ifdef MODE_QUICK
TIMER0_ENABLE;
F_TM=0;
while(!F_TM); //等过起始位
ACC0=BT_REC;
TL0=TH0;
F_TM=0;
while(!F_TM);ACC1=BT_REC;F_TM=0;
while(!F_TM);ACC2=BT_REC;F_TM=0;
while(!F_TM);ACC3=BT_REC;F_TM=0;
while(!F_TM);ACC4=BT_REC;F_TM=0;
while(!F_TM);ACC5=BT_REC;F_TM=0;
while(!F_TM);ACC6=BT_REC;F_TM=0;
while(!F_TM);ACC7=BT_REC;F_TM=0;
while(!F_TM)
if(BT_REC) { break; }
return ACC;
#else
unsigned char rch,ii;
TIMER0_ENABLE;
F_TM=0;
ii=0;
rch=0;
while(ii<8)
rch>>=1;
if(BT_REC)
rch|=0x80;
ii++;
F_TM=0;
while(!F_TM);
F_TM=0;
while(!F_TM)
if(BT_REC)
{ break; }
return rch;
#endif
//检查是不是有起始位
bit StartBitOn()
{return (BT_REC==0);}
void main()
unsigned char gch;
TMOD=0x22; /*定时器1为工作模式2(8位自动重装),0为模式2(8位自动重装) */
PCON=00;
TR0=0; //在发送或接收才开始使用
TF0=0;
TH0=(256-96); //9600bps 就是 1000000/9600=104.167微秒 执行的timer是
// 104.167*11.0592/12= 96
TL0=TH0;
ET0=1;
EA=1;
PSendChar(0x55);
PSendChar(0xaa);
PSendChar(0x00);
PSendChar(0xff);
while(1)
if(StartBitOn())
gch=PGetChar();
PSendChar(gch);
#include <reg51.h>
sbit BT_SND =P1^0;
sbit BT_REC =P1^1;
IO 口模拟232通讯程序
使用两种方式的C程序 占用定时器0
#define MODE_QUICK
#define F_TM F0
sbit ACC0= ACC^0;
sbit ACC1= ACC^1;
sbit ACC2= ACC^2;
sbit ACC3= ACC^3;
sbit ACC4= ACC^4;
sbit ACC5= ACC^5;
sbit ACC6= ACC^6;
sbit ACC7= ACC^7;
F_TM=1;
//发送一个字符
#ifdef MODE_QUICK
ACC=inch;
F_TM=0;
TIMER0_ENABLE; //启动
//先送出低位
while(!F_TM);
#else
unsigned char ii;
ii=0;
F_TM=0;
TIMER0_ENABLE; //启动
while(!F_TM);
while(ii<8)
if(inch&1)
{ BT_SND=1; }
else
{ BT_SND=0; }
F_TM=0;
while(!F_TM);ii++;
inch>>=1;
BT_SND=1;
F_TM=0;
while(!F_TM);
#endif
//接收一个字符
#ifdef MODE_QUICK
TIMER0_ENABLE;
F_TM=0;
ACC0=BT_REC;
TL0=TH0;
F_TM=0;
while(!F_TM)
return ACC;
#else
TIMER0_ENABLE;
F_TM=0;
ii=0;
rch=0;
while(ii<8)
rch>>=1;
if(BT_REC)
rch|=0x80;
ii++;
F_TM=0;
while(!F_TM);
F_TM=0;
while(!F_TM)
if(BT_REC)
{ break; }
return rch;
#endif
//检查是不是有起始位
bit StartBitOn()
void main()
unsigned char gch;
PCON=00;
TF0=0;
TL0=TH0;
ET0=1;
EA=1;
PSendChar(0x55);
PSendChar(0xaa);
PSendChar(0x00);
PSendChar(0xff);
while(1)
if(StartBitOn())
gch=PGetChar();
PSendChar(gch);
| 为遥控小车巧添功能被打赏¥26元 | |
