问
#include<reg51.h>
#define uchar unsigned char
#define uint unsigned int
uchar code c_code[]={0x21};
uchar a_1,a_2,b_1,b_2;
uint key,f,g;
uchar bdata st_f;
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
sbit flag_f1=PSW^1;
sbit flag_f0=PSW^5;
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P1_3=P1^3;
sbit P3_0=P1^0;
sbit P3_1=P1^1;
sbit P3_2=P1^2;
sbit P3_5=P1^5;
sbit P3_7=P1^7;
void int_tr(void) interrupt 0 using 1
{P1_3=1;
if(P1_3==0)
{P1_2=flag_f0;
if(P1_3==1)
P3_1=1;}
if(P3_0==0)
{P1_1=flag_f1;
P3_1=1;
if(P3_0==1)
P3_1=1;}
P1_0=fly;
fly=1;
flag=1;}
void delay(void)
{uchar i,j;
for(i=0;i<=100;i++)
for(j=0;j<=254;j++)
uint hh(void)
{ uchar k;
k=P1;
k=k>>4;
return(c_code[k]);
void main(void)
{TCON=0x01;
delay();
key=hh();
IE=0x81;
caij=0;
while(1)
uchar c_1,c_2,d_1,d_2;
TMOD=0x1d;
TH1=0xfc;
TL1=0x18;
TH0=0;
TL0=0;
TR0=1;
TR1=1;
while(!TF1);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{a_1=TH0;
a_2=TL0; }
else
{c_1=TH0;
c_2=TL0;}
P3_7=1;
fly=1;
if(c_1>a_1)
{P3_7=0;
fly=0;}
f=a_1*256+a_2;
g=c_1*256+c_2;
if(g>f+key)
flag_f0=0;
TMOD=0xd1;
TH0=0xfc;
TL0=0x18;
TH1=0;
TL1=0;
TR0=1;
TR1=1;
while(!TF0);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{b_1=TH1;
b_2=TL1;}
else
{d_1=TH1;
d_2=TL1;}
P3_7=1;
flag=1;
if(d_1>b_1)
{P3_7=0;
flag=0;}
f=b_1*256+b_2;
g=b_1*256+b_2;
if(g>f+key)
flag_f1=0;
caij=1;
key=hh();
if(fly&flag==1)
caij=0;
#include<reg51.h>
uint key,f,g;
uchar bdata st_f;
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
sbit flag_f1=PSW^1;
sbit flag_f0=PSW^5;
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P1_3=P1^3;
sbit P3_0=P1^0;
sbit P3_1=P1^1;
sbit P3_2=P1^2;
sbit P3_5=P1^5;
sbit P3_7=P1^7;
{P1_3=1;
if(P1_3==0)
{P1_2=flag_f0;
if(P1_3==1)
P3_1=1;}
if(P3_0==0)
{P1_1=flag_f1;
P3_1=1;
if(P3_0==1)
P3_1=1;}
P1_0=fly;
fly=1;
flag=1;}
void delay(void)
{uchar i,j;
for(i=0;i<=100;i++)
for(j=0;j<=254;j++)
uint hh(void)
{ uchar k;
k=P1;
k=k>>4;
return(c_code[k]);
void main(void)
{TCON=0x01;
delay();
key=hh();
IE=0x81;
caij=0;
while(1)
TMOD=0x1d;
TH1=0xfc;
TL1=0x18;
TH0=0;
TL0=0;
TR0=1;
TR1=1;
while(!TF1);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{a_1=TH0;
a_2=TL0; }
else
{c_1=TH0;
c_2=TL0;}
P3_7=1;
fly=1;
if(c_1>a_1)
{P3_7=0;
fly=0;}
f=a_1*256+a_2;
g=c_1*256+c_2;
if(g>f+key)
flag_f0=0;
TMOD=0xd1;
TH0=0xfc;
TL0=0x18;
TH1=0;
TL1=0;
TR0=1;
TR1=1;
while(!TF0);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{b_1=TH1;
b_2=TL1;}
else
{d_1=TH1;
d_2=TL1;}
P3_7=1;
flag=1;
if(d_1>b_1)
{P3_7=0;
flag=0;}
f=b_1*256+b_2;
g=b_1*256+b_2;
if(g>f+key)
flag_f1=0;
caij=1;
key=hh();
if(fly&flag==1)
caij=0;
ERROR L107:ADDRESS SPACE OVERFLOW
SPACE:CODE
SEGMENT:?PR?MIAN?2051
LENGTH:00FDH
PROGRAM SIZE:DATA=24.0 XDATA=0 CODE=342
TARGET NOT CREATED
小弟处次用C请指点!
答 1: 这两句有问题。 "
f=a_1*256+a_2;
g=c_1*256+c_2;
类型不匹配。结果不会超过256。 答 2: 谢谢!希望大家继续指出错误,很批!! 答 3: 但编译指出的错与那两条语句无关查一下“{”是否匹配。有无遗漏“;”等 答 4: 程序编译可以通过。 答 5: 谢yangtse,我检查过了,通不过啊 答 6: 怎么两个主函数阿,有问题的是哪个项目呢,看不明白 答 7: 试了可以过的谢yangtse,我检查过了,通不过啊
我试了可以过的。你的编译器是keil uVision2吗? 答 8: 是啊keil uVision2难道是我设置不对吗
应怎么 社 keil uVision2 答 9: 注意格式注意格式,这样怎么看,注意美观。 答 10: 你最好换个编译器再试一下 答 11: 推荐用PC-LINT查。推荐用PC-LINT查。 答 12: 怎么都不看提示?CODE地址空间覆盖冲突
段SEGMENT:?PR?MIAN?2051
LENGTH:00FDH
该不会是楼主从别处拷贝程序时粘贴了2次?
弄出了2个main?
答 13: 最差的是风格,居然没有一句注释!!! 答 14: 看你的c怎么和看汇编一样的感觉啊?我以前用汇编写冬冬时注释不比代码少,看起来也没有这么吃力
答 15: 呵呵!我也觉得!你就不怕你忘了某句是什么意思吗?加点注释吧! 答 16: 我也有这种感决 答 17: 这几句是什么? uchar bdata st_f;
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
我晕
答 18: 酷!居然把C做的具有汇编的境界! 答 19: 一点建议 uchar bdata st_f;
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
定义位变量不用这么复杂的,直接bit fly,flag,caij;岂不方便?还省了一个st_f变量。sbit 一般是用来定义管脚的。SFR的设置一般单独写到子程序里,不要加到主程序中,这样显得很乱。另外,uchar code c_code[]={0x21};
return(c_code[k]); 不明白你要做什么,你的数组只有一个数据,还c_code[k]);
要作什么?感觉楼主还没有明白数组的用法,建议最好还是先弄懂了再用。
uint key,f,g;
uchar bdata st_f;
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
sbit flag_f1=PSW^1;
sbit flag_f0=PSW^5;
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P1_3=P1^3;
sbit P3_0=P1^0;
sbit P3_1=P1^1;
sbit P3_2=P1^2;
sbit P3_5=P1^5;
sbit P3_7=P1^7;
{P1_3=1;
if(P1_3==0)
{P1_2=flag_f0;
if(P1_3==1)
P3_1=1;}
if(P3_0==0)
{P1_1=flag_f1;
P3_1=1;
if(P3_0==1)
P3_1=1;}
P1_0=fly;
fly=1;
flag=1;}
void delay(void)
{uchar i,j;
for(i=0;i<=100;i++)
for(j=0;j<=254;j++)
uint hh(void)
{ uchar k;
k=P1;
k=k>>4;
return(c_code[k]);
void main(void)
{TCON=0x01;
delay();
key=hh();
IE=0x81;
caij=0;
while(1)
TMOD=0x1d;
TH1=0xfc;
TL1=0x18;
TH0=0;
TL0=0;
TR0=1;
TR1=1;
while(!TF1);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{a_1=TH0;
a_2=TL0; }
else
{c_1=TH0;
c_2=TL0;}
P3_7=1;
fly=1;
if(c_1>a_1)
{P3_7=0;
fly=0;}
f=a_1*256+a_2;
g=c_1*256+c_2;
if(g>f+key)
flag_f0=0;
TMOD=0xd1;
TH0=0xfc;
TL0=0x18;
TH1=0;
TL1=0;
TR0=1;
TR1=1;
while(!TF0);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{b_1=TH1;
b_2=TL1;}
else
{d_1=TH1;
d_2=TL1;}
P3_7=1;
flag=1;
if(d_1>b_1)
{P3_7=0;
flag=0;}
f=b_1*256+b_2;
g=b_1*256+b_2;
if(g>f+key)
flag_f1=0;
caij=1;
key=hh();
if(fly&flag==1)
caij=0;
#include<reg51.h>
uint key,f,g;
uchar bdata st_f;
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
sbit flag_f1=PSW^1;
sbit flag_f0=PSW^5;
sbit P1_0=P1^0;
sbit P1_1=P1^1;
sbit P1_2=P1^2;
sbit P1_3=P1^3;
sbit P3_0=P1^0;
sbit P3_1=P1^1;
sbit P3_2=P1^2;
sbit P3_5=P1^5;
sbit P3_7=P1^7;
{P1_3=1;
if(P1_3==0)
{P1_2=flag_f0;
if(P1_3==1)
P3_1=1;}
if(P3_0==0)
{P1_1=flag_f1;
P3_1=1;
if(P3_0==1)
P3_1=1;}
P1_0=fly;
fly=1;
flag=1;}
void delay(void)
{uchar i,j;
for(i=0;i<=100;i++)
for(j=0;j<=254;j++)
uint hh(void)
{ uchar k;
k=P1;
k=k>>4;
return(c_code[k]);
void main(void)
{TCON=0x01;
delay();
key=hh();
IE=0x81;
caij=0;
while(1)
TMOD=0x1d;
TH1=0xfc;
TL1=0x18;
TH0=0;
TL0=0;
TR0=1;
TR1=1;
while(!TF1);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{a_1=TH0;
a_2=TL0; }
else
{c_1=TH0;
c_2=TL0;}
P3_7=1;
fly=1;
if(c_1>a_1)
{P3_7=0;
fly=0;}
f=a_1*256+a_2;
g=c_1*256+c_2;
if(g>f+key)
flag_f0=0;
TMOD=0xd1;
TH0=0xfc;
TL0=0x18;
TH1=0;
TL1=0;
TR0=1;
TR1=1;
while(!TF0);
TF1=0;
TR0=0;
TR1=0;
if(caij==0)
{b_1=TH1;
b_2=TL1;}
else
{d_1=TH1;
d_2=TL1;}
P3_7=1;
flag=1;
if(d_1>b_1)
{P3_7=0;
flag=0;}
f=b_1*256+b_2;
g=b_1*256+b_2;
if(g>f+key)
flag_f1=0;
caij=1;
key=hh();
if(fly&flag==1)
caij=0;
SPACE:CODE
LENGTH:00FDH
TARGET NOT CREATED
小弟处次用C请指点!
答 1: 这两句有问题。 "
f=a_1*256+a_2;
g=c_1*256+c_2;
LENGTH:00FDH
弄出了2个main?
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
我晕
sbit fly=st_f^0;
sbit flag=st_f^1;
sbit caij=st_f^2;
