问
我做的24C02的存取实验中:
为什么第二次读数据的时候,会接着第一次的读?(程序重新运行了)
谢谢指点!
程序如下:BITCNT EQU 40H
SUBADR EQU 41H
SDA BIT P1.6
SCL BIT P1.5
ORG 00H
JMP MAIN
ORG 0100H
MAIN:
SETB P1.0
MOV R6,#4
LOPP:
ACALL DELAY
ACALL READ_24C02
INC SUBADR
ACALL DELAY
MOV P2,A
ACALL DELAY
MOV P2,#0FFH
ACALL DELAY
DJNZ R6,LOPP
;JMP MAIN
DELAY: MOV R0,#0FFH
DELAY0: MOV R1,#0FFH
DELAY1: NOP
NOP
NOP
DJNZ R1,DELAY1
DJNZ R0,DELAY0
RET
READ_24C02:
ACALL START
MOV A,#0A0H
ACALL SENTBYTE
JB F0,RCVRETURN
MOV A,SUBADR
ACALL SENTBYTE
JB F0,RCVRETURN
ACALL START
MOV A,#0A0H
SETB ACC.0
ACALL SENTBYTE
JB F0,RCVRETURN
ACALL RCVBYTE
RCVRETURN:
RET
START:
SETB SDA
NOP
NOP
NOP
SETB SCL
NOP
NOP
NOP
CLR SDA
NOP
NOP
NOP
CLR SCL
RET
STOP:
CLR SDA
NOP
NOP
NOP
SETB SCL
NOP
NOP
NOP
SETB SDA
NOP
NOP
NOP
NOP
RET
SENTBYTE:
MOV BITCNT,#08H
SENTB:
RLC A
MOV SDA,C
NOP
NOP
NOP
SETB SCL
NOP
NOP
NOP
CLR SCL
DJNZ BITCNT,SENTB
NOP
NOP
SETB SDA
NOP
NOP
SETB SCL
NOP
NOP
CLR F0
JNB SDA,ACKEND
SETB F0
ACKEND:
NOP
CLR SCL
RET
RCVBYTE:
SETB SDA
MOV BITCNT,#08H
RCV:
NOP
CLR SCL
NOP
NOP
NOP
NOP
NOP
SETB SCL
NOP
NOP
MOV C,SDA
RLC A
NOP
NOP
DJNZ BITCNT,RCV
CLR SCL
NOP
NOP
CLR SDA
SETB SDA
NOP
NOP
SETB SCL
NOP
NOP
SETB SDA
NOP
NOP
NOP
CLR SCL
RET
END
答 1: 有没有人能帮帮我???? 答 2: 你能不能先把IIC写好,写24c02不就很简单了 答 3: 仿真看看是不是第2次读的时候SUBADR没改变?READEEPROM:
CALL STARTE2 ;开始
LD R1,#0A0H
CALL WR_BYTE
LD R1,R2 ;R2是需要读取数据的地址
CALL WR_BYTE
CALL STARTE2
LD R1,#0A1H
CALL WR_BYTE
CALL RD_BYTE ;输出r0是读取的数据
LD R3,R0
CALL SNACK
CALL EPSTOP
CALL DELAY20MS
RET
重复调用的时候只需要增加r2,r3的地址就ok
谢谢指点!
程序如下:BITCNT EQU 40H
SUBADR EQU 41H
SDA BIT P1.6
SCL BIT P1.5
ORG 00H
JMP MAIN
ORG 0100H
MAIN:
SETB P1.0
MOV R6,#4
LOPP:
ACALL DELAY
ACALL READ_24C02
INC SUBADR
ACALL DELAY
MOV P2,A
ACALL DELAY
MOV P2,#0FFH
ACALL DELAY
DJNZ R6,LOPP
;JMP MAIN
DELAY: MOV R0,#0FFH
DELAY1: NOP
NOP
NOP
DJNZ R1,DELAY1
DJNZ R0,DELAY0
RET
READ_24C02:
ACALL START
MOV A,#0A0H
ACALL SENTBYTE
JB F0,RCVRETURN
MOV A,SUBADR
ACALL SENTBYTE
JB F0,RCVRETURN
ACALL START
MOV A,#0A0H
SETB ACC.0
ACALL SENTBYTE
JB F0,RCVRETURN
ACALL RCVBYTE
RCVRETURN:
RET
START:
SETB SDA
NOP
NOP
NOP
SETB SCL
NOP
NOP
NOP
CLR SDA
NOP
NOP
NOP
CLR SCL
RET
STOP:
CLR SDA
NOP
NOP
NOP
SETB SCL
NOP
NOP
NOP
SETB SDA
NOP
NOP
NOP
NOP
RET
SENTBYTE:
MOV BITCNT,#08H
SENTB:
RLC A
MOV SDA,C
NOP
NOP
NOP
SETB SCL
NOP
NOP
NOP
CLR SCL
DJNZ BITCNT,SENTB
NOP
NOP
SETB SDA
NOP
NOP
SETB SCL
NOP
NOP
CLR F0
JNB SDA,ACKEND
SETB F0
ACKEND:
NOP
CLR SCL
RET
RCVBYTE:
SETB SDA
MOV BITCNT,#08H
RCV:
NOP
CLR SCL
NOP
NOP
NOP
NOP
NOP
SETB SCL
NOP
NOP
MOV C,SDA
RLC A
NOP
NOP
DJNZ BITCNT,RCV
CLR SCL
NOP
NOP
CLR SDA
SETB SDA
NOP
NOP
SETB SCL
NOP
NOP
SETB SDA
NOP
NOP
NOP
CLR SCL
RET
END
CALL STARTE2 ;开始
LD R1,#0A0H
CALL WR_BYTE
CALL WR_BYTE
CALL STARTE2
LD R1,#0A1H
CALL WR_BYTE
LD R3,R0
CALL SNACK
CALL EPSTOP
CALL DELAY20MS
RET
