问
大侠们帮我看一下这个定时中断为什么不产生中断呢,哪根筋没对?????????
void timer0int( ) interrupt 1 using 2 //定时器0中断服务程序
delay_int_times++;
void start_timer0(unsigned char int_times)
TMOD=0x01; //方式1,定时100ms(6M晶振50000次)
TH0=-(50000/256);
TL0=-(50000%256);
EA=1;
ET0=1;
TR0=1;
delay_int_times=0;
while(delay_int_times!=int_times)
ET0=0;
TR0=0;
} 答 1: 有中断啊.具体什么问题?#include <reg52.h>
unsigned char delay_int_times;
delay_int_times++;
TH0=-(50000/256);
TL0=-(50000%256);
EA=1;
ET0=1;
TR0=1;
delay_int_times=0;
ET0=0;
TR0=0;
void main()
while(1)
start_timer0(100);
} 答 2: 设置好断点在中断服务程序中等,始终不进中断服务程序啊!!!!! 答 3: re把我上面的程序在KEIL C中试试,我试过了可以进中断的. 答 4: 哦!!对了,我的仿真器有点问题!! 答 5: 定时器没有重载 答 6: 同意toonaive的
delay_int_times++;
TH0=-(50000/256);
TL0=-(50000%256);
EA=1;
ET0=1;
TR0=1;
delay_int_times=0;
ET0=0;
TR0=0;
delay_int_times++;
TH0=-(50000/256);
TL0=-(50000%256);
EA=1;
ET0=1;
TR0=1;
delay_int_times=0;
ET0=0;
TR0=0;
void main()
while(1)
start_timer0(100);
