ADS1 ADS1。2中怎么嵌入汇编语言呢?
问
各位大哥:
有个问题我不太明白,请问在ADS1。2的C编译环境下,怎么嵌入汇编程序呢?怎么调用由汇编语言做的函数呢?请指点一二,谢谢。
答 1: 这个参观一下44b0的boot代码就明白了不管是C语言,还是汇编语言,它们的函数和变量都在符号表中存在.只要申明该变量或者函数为全局变量,那么汇编和C语言就可以互相调用.
在C语言中嵌入少量汇编的语句是:
_asm_(....) 答 2: C嵌入汇编的方法很多资料书籍都有介绍,方法如下:
__ARM
LDR R5,[R6]
答 3: 不行哦,老兄刚才试了一下两位建议的方法,好像都不能编译呢,代码如下:
OS_ENTER_CRITICAL();
__ARM
LDR R5,[R6]
MRS r0, cpsr
temp =0x1234;
出错:
Error : C2456E: undeclared name, inventing 'extern int __ARM'
Main.c line 558
Error : (Serious) C2284E: expected ';' after command - inserted before '{'
Main.c line 558
Error : C2456E: undeclared name, inventing 'extern int LDR'
Main.c line 559
Error : (Serious) C2284E: expected ';' after command - inserted before 'R5'
Main.c line 559
Error : C2456E: undeclared name, inventing 'extern int R5'
Main.c line 559
Error : (Serious) C2291E: <expression> expected but found ''
Main.c line 559
Error : C2456E: undeclared name, inventing 'extern int R6'
Main.c line 559
Error : (Serious) C2284E: expected ';' after command - inserted before 'MRS'
Main.c line 560
Error : C2456E: undeclared name, inventing 'extern int MRS'
Main.c line 560
Error : (Serious) C2284E: expected ';' after command - inserted before 'r0'
Main.c line 560
Error : C2456E: undeclared name, inventing 'extern int r0'
Main.c line 560
Error : C2456E: undeclared name, inventing 'extern int cpsr'
Main.c line 561
Error : (Serious) C2284E: expected ';' after command - inserted before '}'
Main.c line 561
答 4: 是不是哪里还好设置?是不是哪里还好设置? 答 5: herder file ok??
在C语言中嵌入少量汇编的语句是:
__ARM
LDR R5,[R6]
__ARM
LDR R5,[R6]
MRS r0, cpsr
temp =0x1234;
出错:
Main.c line 558
Main.c line 558
Main.c line 559
Main.c line 559
Main.c line 559
Main.c line 559
Main.c line 559
Main.c line 560
Main.c line 560
Main.c line 560
Main.c line 560
Main.c line 561
Main.c line 561
