printer,problem printer problem
问
14.0 CTL 80 06 00 01 00 00 12 00 GET DESCRIPTOR 1.1.0
14.0 LEN 12 00 00 00 18 1.2.0
14.0 DI 12 01 10 01 00 00 00 08 f0 03 17 0c 00 01 01 02 ................ 1.3.0
03 01 .. 1.3.16
14.0 CTL 80 06 00 02 00 00 09 01 GET DESCRIPTOR 2.1.0
14.0 LEN 4e 00 00 00 78 2.2.0
14.0 DI 09 02 4e 00 01 01 00 c0 01 09 04 00 00 03 07 01 ..N............. 2.3.0
03 00 07 05 01 02 40 00 00 07 05 81 02 40 00 00 ......@......@.. 2.3.16
07 05 82 03 08 00 ff 09 04 00 01 02 07 01 02 00 ................ 2.3.32
07 05 01 02 40 00 00 07 05 81 02 40 00 00 09 04 ....@......@.... 2.3.48
00 02 01 07 01 01 00 07 05 01 02 40 00 00 ...........@.. 2.3.64
14.0 CTL 00 09 01 00 00 00 00 00 SET CONFIG 3.1.0
14.0 CTL a1 00 00 00 00 00 ff 00 GET DEVICE ID 4.1.0
14.0 LEN 8f 00 00 00 143 4.2.0
14.0 DI 00 8f 4d 46 47 3a 48 65 77 6c 65 74 74 2d 50 61 ..MFG:Hewlett-Pa 4.3.0
63 6b 61 72 64 3b 43 4d 44 3a 50 4a 4c 2c 4d 4c ckard;CMD:PJL,ML 4.3.16
43 2c 42 49 44 49 2d 45 43 50 2c 44 57 2d 50 43 C,BIDI-ECP,DW-PC 4.3.32
4c 3b 4d 44 4c 3a 68 70 20 4c 61 73 65 72 4a 65 L;MDL:hp LaserJe 4.3.48
74 20 31 30 31 30 3b 43 4c 53 3a 50 52 49 4e 54 t 1010;CLS:PRINT 4.3.64
45 52 3b 44 45 53 3a 48 65 77 6c 65 74 74 2d 50 ER;DES:Hewlett-P 4.3.80
61 63 6b 61 72 64 20 4c 61 73 65 72 4a 65 74 20 ackard LaserJet 4.3.96
31 30 31 30 3b 4d 45 4d 3a 35 4d 42 3b 43 4f 4d 1010;MEM:5MB;COM 4.3.112
4d 45 4e 54 3a 52 45 53 3d 36 30 30 78 31 3b MENT:RES=600x1; 4.3.128
以上是USB printer 的描述符,
有谁知道 MFG, CMD, MDL, CLS, DES, MEM and COMMENT 表示什么意思吗?
请不吝赐教, 谢谢
dery.zheng@163.com
答 1: 这那是Printer的问题,明明是你的英语问题MFG = Manufacture
CMD = Command
MDL = .... 忘记了,这是HP的一个用于打印机的描述语言。
DL = Description Language
CLS = Class (估计是)
DES = Description
MEM = Memory
COMMENT = Comment = 注释,注解
03 01 .. 1.3.16
请不吝赐教, 谢谢
dery.zheng@163.com
CMD = Command
CLS = Class (估计是)
DES = Description
MEM = Memory
