Kernel,panic,not,syncing,VFS,Unable,to,mount,root Kernel panic - not syncing: VF
问
Linux....................................................................................... done, booting the kernel.
Linux version 2.6.16.28 (root@fla) (gcc version 3.4.1) #5 Sat Sep 9 11:55:33 CST 2006
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
Machine: SMDK2410
Warning: bad configuration page, trying to continue
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C2440: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists
Kernel command line: root=/dev/mtdblock2 init=/bin/bash console=ttySAC1
irq: clearing pending ext status 00007000
irq: clearing subpending status 0000009a
irq: clearing subpending status 00000092
PID hash table entries: 128 (order: 7, 2048 bytes)
timer tcon=00090000, tcnt a2c1, tcfg 00000200,00000000, usec 00001eb8
Console: colour dummy device 80x30
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 16MB = 16MB total
Memory: 13320KB available (2245K code, 504K data, 108K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, UPLL 96.000 MHz, DVS off
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c1800000, irq 33
DMA channel 1 at c1800040, irq 34
DMA channel 2 at c1800080, irq 35
DMA channel 3 at c18000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
JFFS version 1.0, (C) 1999, 2000 Axis Communications AB
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
s3c2410-lcd s3c2410-lcd: no platform data for lcd, CANnot attach
s3c2410-lcd: probe of s3c2410-lcd failed with error -22
lp: driver loaded but no devices found
S3C2410 RTC, (c) 2004 Simtec Electronics
ppdev: user-space parallel port driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: loaded (max 8 devices)
dm9000 Ethernet Driver
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
BAST NOR-Flash Driver, (c) 2004 Simtec Electronics
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand: Tacls=1, 10ns Twrph0=4 40ns, Twrph1=1 10ns
No NAND device found!!!
NAND device: Manufacturer ID: 0x98, Chip ID: 0x39 (Toshiba NAND 8MiB 1,8V 8-bit)
flash size: 8 MiB
page size: 512 bytes
OOB area size: 16 bytes
sector size: 8 KiB
pages number: 16384
pages per sector: 16
bus width: 8
bits in sector size: 13
bits in page size: 9
bits in OOB size: 4
flash size with OOB: 8448 KiB
page address bytes: 3
sector address bytes: 2
options: 0x62
SCANning device for bad blocks
Creating 1 MTD partitions on "NAND 8MiB 1,8V 8-bit":
0x00000000-0x00800000 : "NAND simulator partition"
mice: PS/2 mouse device common for all mice
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 390 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
NET: Registered protocol family 2
IP route cache hash table entries: 256 (order: -2, 1024 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
TCP bic registered
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: CANnot open root device "mtdblock2" or unknown-block(2,0)
Please append a correct "root=" boot option
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
nandflash是使用的和smdk2410一样的k9f1208,所以nandflash的驱动应该内核已经默认包含了吧,但为什么会出现No NAND device found!!!呢??
请解决过的朋友说两句,谢谢 答 1: Creating 1 MTD partitions on "NAND 8MiB 1,8V 8-bit": 答 2: 这个不是硬件上的nandflash硬件上nandflash是64M的,会出现Creating 1 MTD partitions on "NAND 8MiB 1,8V 8-bit"应该是内核选中在mtd nand layer模拟nandflash导致的
Machine: SMDK2410
Built 1 zonelists
flash size: 8 MiB
sector size: 8 KiB
pages number: 16384
bus width: 8
bits in OOB size: 4
options: 0x62
TCP reno registered
TCP bic registered
