SmartRAM2200,uclinux 在SmartRAM2200板上用自带的uclinux内核烧写后启动有错误?
问
Start User's Program...Linux version 2.4.24-uc0 (root@vcmj) (gcc version 2.95.35Processor: philip lpc2200 revision 14
Architecture: zlg-ARM-linux
Ignoring unrecognised tag 0x00000000
On node 0 totalpages: 2048
zone(0): 0 pages.
zone(1): 2048 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/ram
Calibrating delay loop... 1.93 BogoMIPS
Memory: 8MB = 8MB total
Memory: 5876KB available (962K code, 183K data, 40K init)
Dentry cache hash table entries: 1024 (order: 1, 8192 bytes)
Inode cache hash table entries: 512 (order: 0, 4096 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 2048 (order: 1, 8192 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Serial driver version 5.05c (2001-07-08) with no serial options enabled
ttyS00 at 0xe000c000 (irq = 6) is a 16550A
ttyS01 at 0xe0010000 (irq = 7) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 512)
RAMDISK: ext2 filesystem found at block 0
RAMDISK: Loading 1000 blocks [1 disk] into ram disk... done.
Freeing initrd memory: 1024K
VFS: Mounted root (ext2 filesystem) readonly.
Freeing init memory: 40K
Shell invoked to run file: /etc/rc
Command: hostname GDB-ARMulator
Command: /bin/expand /etc/ramfs.img /dev/ram1
Command: mount -n -o remount,rw /
Command: mount -t proc proc /proc
Command: mount -t ext2 /dev/ram1 /var
Command: insmod /bin/zlg_ffs
Using /bin/zlg_ffs
Warning: loading zlg_ffs will taint the kernel: non-GPL license - Proprietary
See http://www.tux.org/lkml/#export-tainted for information about tainted modszlg_ffs: zlg_ffs_init OK
Command: mount /dev/zlg_ffs /usr
VFS: CAN't find ext2 filesystem on dev zlg_ffs(126,0).
kmod: failed to exec /sbin/modprobe -s -k nls_cp437, errno = 2
kmod: failed to exec /sbin/modprobe -s -k nls_iso8859-1, errno = 2
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: /usr/etc/rc
BINFMT_FLAT: Loading file: /usr/etc/rc
BINFMT_FLAT: bad magic/rev (0x6f64202f, need 0x4)
Shell invoked to run file: /usr/etc/rc
Command: insmod /usr/bin/rtl8019
Using /usr/bin/rtl8019
Warning: loading rtl8019 will taint the kernel: non-GPL license - Proprietary
See http://www.tux.org/lkml/#export-tainted for information about tainted modseth0: init OK
Command: ifconfig eth0 192.168.0.115
Command: ifconfig eth0 netmask 255.255.255.0
Command: ifconfig eth0 down
Command: ifconfig eth0 hw ether 00:14:97:0f:09:63
Command: ifconfig eth0 up
Command: route add default gw 192.168.0.1
Execution Finished, Exiting
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/ \
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
GDB/ARMulator support by <davidm@snapgear.com>
For further information check:
http://www.uclinux.org/
Sash command shell (version 1.1.1)
答 1: 是啊ARM技术交流(群号)
27411611
zone(0): 0 pages.
zone(2): 0 pages.
Starting kswapd
Using /bin/zlg_ffs
Welcome to
____ _ _
/ __| ||_|
| | | | | | || | _ \| | | |\ \/ /
|_|
答 1: 是啊ARM技术交流(群号)
27411611
