简单的锁存器 8位数据锁存器
// Latch Inference
// download from: http://www.fpga.com.cn
module latchinf(enable, data, q);
input enable, data;
output q;
reg q;
always @(enable or data)
if (enable)
q <= data;
endmodule
12位寄存器 带load,clr等功能的寄存器// Register Inference
module reginf(d, clk, clr, pre, load, data,
q1, q2, q3, q4, q5, q6, q7);
input d, clk, clr, pre, load, data;
output q1, q2, q3, q4, q5, q6, q7;
reg q1, q2, q3, q4, q5, q6, q7;
// Register with active-high Clock
always @(posedge clk)
q1 = d;
// Register with active-low Clock
always @(negedge clk)
q2 = d;
// Register with active-high Clock & asynchronous Clear
always @(posedge clk or posedge clr) begin
if (clr)
q3 = 0;
else
q3 = d;
end
// Register with active-low Clock & asynchronous Clear
always @(negedge clk or negedge clr) begin
if (!clr)
q4 = 0;
else
q4 = d;
end
// Register with active-high Clock & asynchronous Preset
always @(posedge clk or posedge pre) begin
if (pre)
q5 = 1;
else
q5 = d;
end
// Register with active-high Clock & asynchronous Load
always @(posedge clk or posedge load) begin
if (load)
q6 = data;
else
q6 = d;
end
// Register with active-high Clock & asynchronous Clear & Preset
always @(posedge clk or posedge clr or posedge pre) begin
if (clr)
q7 = 0;
else if (pre)
q7 = 1;
else
q7 = d;
end
endmodule
移位寄存器
// DESCRIPTION : Shift register
// Type : univ
// Width : 4
// Shift direction: right/left (right active high)
// CLK active : high
// CLR active : high
// CLR type : synchronous
// SET active : high
// SET type : synchronous
// LOAD active : high
// CE active : high
// SERIAL input : SI
// Download from : http://www.pld.com.cn
module shft_reg (CLR , SET , DIR , CE , LOAD , DATA , SI , data_out , CLK );
input CLR , SET , CE , LOAD , DIR , SI , CLK ;
input [3:0] DATA ;
output [3:0] data_out ;
reg [3:0] TEMP;
always @(posedge CLK )
begin
if (CE == 1'b1)
if (CLR == 1'b1)
TEMP = {4{1'b0}};
else if (SET == 1'b1)
TEMP = {4{1'b1}};
else if (LOAD == 1'b1)
TEMP = DATA ;
else if (DIR == 1'b1)
TEMP = {SI , TEMP [3:1]};
else
TEMP = {TEMP [2:0], SI };
end
assign data_out = TEMP;
endmodule
各种类型计数器 // Efficient Counter Inference
// download from: www.pld.com.cn & www.fpga.com.cn
module counters (d, clk, clear, ld, enable, up_down,
qa, qb, qc, qd, qe, qf, qg,
qh, qi, qj, qk, ql, qm, qn);
input [7:0] d;
input clk, clear, ld, enable, up_down;
output [7:0] qa, qb, qc, qd, qe, qf, qg;
output [7:0] qh, qi, qj, qk, ql, qm, qn;
reg [7:0] qa, qb, qc, qd, qe, qf, qg;
reg [7:0] qh, qi, qj, qk, ql, qm, qn;
integer direction;
// An enable counter
begin
if (enable)
qa = qa + 1;
end
// A synchronous load counter
begin
if (!ld)
qb = d;
else
qb = qb + 1;
end
// A synchronous clear counter
begin
if (!clear)
qc = 0;
else
qc = qc + 1;
end
// An up/down counter
begin
if (up_down)
direction = 1;
else
direction = -1;
qd = qd + direction;
end
// A synchronous load enable counter
always @ (posedge clk)
begin
if (!ld)
qe = d;
else if (enable)
qe = qe + 1;
end
// An enable up/down counter
begin
if (up_down)
direction = 1;
else
direction = -1;
if (enable)
qf = qf + direction;
end
// A synchronous clear enable counter
begin
if (!clear)
qg = 0;
else if (enable)
qg = qg + 1;
end
// A synchronous load clear counter
begin
if (!clear)
qh = 0;
else if (!ld)
qh = d;
else
qh = qh + 1;
end
// A synchronous load up/down counter
begin
if (up_down)
direction = 1;
else
direction = -1;
if (!ld)
qi = d;
else
qi = qi + direction;
end
// A synchronous load enable up/down counter
begin
if (up_down)
direction = 1;
else
direction = -1;
if (!ld)
qj = d;
else if (enable)
qj = qj + direction;
end
// A synchronous clear load enable counter
begin
if (!clear)
qk = 0;
else if (!ld)
qk = d;
else if (enable)
qk = qk + 1;
end
// A synchronous clear up/down counter
begin
if (up_down)
direction = 1;
else
direction = -1;
if (!clear)
ql = 0;
else if (enable)
ql = ql + direction;
end
// A synchronous clear enable up/down counter
begin
if (up_down)
direction = 1;
else
direction = -1;
if (!clear)
qm = 0;
else if (enable)
qm = qm + direction;
end
// A modulus 200 up counter
begin
if (qn == 200)
qn = 0;
else
qn = qn + 1;
end
endmodule
