Quartus II 7.2的重大改进
4个方面改进最大:
n State Machine Diagram Entry
- Two Methods for Entry
l Graphical Entry, user enters the state-machine using bubble diagram
l Text based Entry, user enters the state-machine using a Wizard
l Auto generation of HDLs (Verilog and VHDL)
FFT IP:
n 32-bit floating point support for Radix 2 variable streaming cores。
终于支持MMU了,但是Altera没有说明是否支持Vxworks:
Nios II & EDS |
Embedded Systems |
n MMU support - Hidden from general use, OS required - Release is for OS port start n Improved protection features for illegal operations - Hidden from general use, requires tech specialist engagement. - Primary customers Huawei and Motorola |
n Stratix II, HardCopy II
- Military temperature grade support
- Military ordering codes for HardCopy II
