给你一个源码看看!
void i2c_init(void)
PACNT_init;
PADDR_init;
PADAT_init;
SCL_high;
SDA_high;
uint8 i2c_write(uint8 slave_address, uint8 *buffer, int byte_count, int freq)
uint8 out_mask = 0x80;
uint8 value = 0x00;
uint8 send_byte = 0x00;
uint8 status = 0x81;
int count = 8;
int clk_count = 0;
int i = 0;
/* Set delay value based on frequency. */
int D = (int) ((4000/freq) - 14);
slave_address = (slave_address & 0xFE);
i2c_start();
delay(500);
send_byte = slave_address;
for(i = 0; i <= byte_count; i++)
count = 8;
out_mask = 0x80;
/* Send data bytes one bit at a time. */
while(count > 0)
value = ((send_byte & out_mask) ? 1 : 0);
if (value == 1)
PADAT_init;
SDA_high;}
else
PADAT_init;
SDA_low;}
delay(D);
PADAT_init;
SCL_high;
/* Clock stretching wait statement. Wait until clock is released
by slave. Only effects program on first iteration. */
while (((GPIO_PADAT & 0x0200) ? 1 : 0) == 0){;}
delay(2*D);
PADAT_init;
SCL_low;
delay(D);
out_mask >>= 1;
count--;
PADAT_init;
SDA_high; /* Let go of data pin. */
delay(D);
if (((GPIO_PADAT & 0x0400) ? 1 : 0) == 1)
status = 0xA1; /* Transfer complete, bus busy, acknowledge not received. */
break; } /* If not acknowledged, exit loop. */
PADAT_init;
SCL_high;
delay(2*D);
PADAT_init;
SCL_low;
status = 0xA0; /* Transfer complete, bus busy, acknowledge received. */
delay(D);
send_byte = buffer[i];
PADAT_init;
SDA_high;
SCL_low;
delay(100);
return(status);
uint8 i2c_read(uint8 slave_address, uint8 *buffer, int byte_count, int freq)
uint8 input_byte = 0x00;
uint8 value = 0x00;
int count = 8;
int clk_count = 0;
int i = 0;
slave_address = (slave_address | 0x01);
i2c_start();
delay(500);
/********** Write Address Procedure **********/
while(count > 0)
value = ((slave_address & out_mask) ? 1 : 0);
if (value == 1)
PADAT_init;
SDA_high;}
else
PADAT_init;
SDA_low;}
delay(D);
PADAT_init;
SCL_high;
/* Clock stretching wait. Wait until clock is released
by slave. */
delay(2*D);
PADAT_init;
SCL_low;
delay(D);
out_mask >>= 1;
count--;
PADAT_init;
delay(D);
SCL_high;
delay(2*D);
/* If not acknowleged, set status accordingly and exit read process. */
status = 0xA1;
return(status);}
PADAT_init;
SCL_low;
delay(D);
/********** Begin Read Procedure **********/
/* Release SDA and SCL to initiate transfer. */
PADAT_init;
SDA_high;
SCL_high;
for(i = 0; i < byte_count; i++)
count = 8;
input_byte = 0x00;
PADAT_init;
SCL_high;
by slave. */
/* Loop for bit-by-bit read of data. */
while(count > 0)
PADAT_init;
SCL_high;
delay(D);
delay(4); /* Required to make read and write clocks the same freq. */
if ((GPIO_PADAT & 0x0600) == 0x0600)
input_byte++;
delay(D);
PADAT_init;
SCL_low;
delay(2*D);
if (count == 1)
break;
else
input_byte <<= 1;
count--;
/* Write input byte to "read_buffer". */
buffer[i] = input_byte;
if(i == (byte_count - 1))
break;
/* Below is the acknowledge procedure. */
PADAT_init;
SDA_low;
delay(D);
SCL_high;
delay(2*D);
PADAT_init;
SCL_low;
delay(D);
SDA_high;
status = 0xA0;
/* Standard protocol calls for the last read byte to
not receive an acknowledge from the master. */
PADAT_init;
SDA_high;
SCL_high;
delay(2*D);
PADAT_init;
SCL_low;
delay(D);
SDA_high;
status = 0xA1;
return(status);
void i2c_start(void)
int clk_count = 0;
uint8 compare = 0x00;
PADAT_init;
SDA_high;
delay(100);
PADAT_init;
SCL_high;
delay(100);
by slave. */
PADAT_init;
SDA_low;
delay(100);
PADAT_init;
SCL_low;
delay(100);
uint8 i2c_stop(void)
uint8 status = 0x00;
int clk_count = 0;
PADAT_init;
SCL_low;
delay(100);
PADAT_init;
SDA_low;
delay(100);
PADAT_init;
SCL_high;
by slave. */
delay(100);
PADAT_init;
SDA_high;
status = 0x81; /* Set bus idle. */
return(status);
void delay(int value)
int clk_count = 0;
while (clk_count < value)
{clk_count++;}
