电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » USART接485发送+PROTESU仿真
2009-03-13 02:38:41     打赏
仿真截图
点击开大图
//ICC-AVR application builder : 2007-11-30 20:29:49
//串口+485发送程序
// Target : M16
// Crystal: 8.0000Mhz
//编制:孙可
#include <iom16v.h>
#include <macros.h>
void x_print(unsigned char c) //发送采用查询方式
while( !(UCSRA & (1<<UDRE)) );
UDR=c;
void port_init(void)
PORTA = 0x00;
DDRA = 0x00;
PORTB = 0x00;
DDRB = 0x00;
PORTC = 0x00; //m103 output only
DDRC = 0x00;
PORTD = 0x40;
DDRD = 0x40;
//UART0 initialize
// desired baud rate: 9600
// actual: baud rate:9615 (0.2%)
void uart0_init(void)
UCSRB = 0x00; //disable while setting baud rate
UCSRA = 0x00;
UCSRC = BIT(URSEL) | 0x0E;
UBRRL = 0x33; //set baud rate lo
UBRRH = 0x00; //set baud rate hi
UCSRB = 0x98;
#pragma interrupt_handler uart0_rx_isr:iv_USART0_RXC
void uart0_rx_isr(void)
//uart has received a character in UDR
//call this routine to initialize all peripherals
void init_devices(void)
//stop errant interrupts until set up
CLI(); //disable all interrupts
port_init();
uart0_init();
MCUCR = 0x00;
GICR = 0x00;
TIMSK = 0x00; //timer interrupt sources
SEI(); //re-enable interrupts
//all peripherals are now initialized
void main(void)
init_devices();
while(1)
unsigned int i="0x55";
unsigned int j="0xaa";
x_print(i);
x_print(j);
关键词: USART     485发送     +PROTESU     仿真
