共8条
datasheet,点了出这个错误~
exception 'Zend_Session_Exception' with message 'Zend_Session::start() - session_start() [function.session-start]: open(/tmp/sess_ada49f82b1502bf99d99847a029887cc, O_RDWR) failed: Read-only file system (30)' in /var/www/library/Zend/Session.php:379 Stack trace: #0 /var/www/library/Zend/Session/Namespace.php(116): Zend_Session::start(true) #1 /var/www/library/Zend/Auth/Storage/Session.php(85): Zend_Session_Namespace->__construct('Zend_Auth') #2 /var/www/library/Zend/Auth.php(92): Zend_Auth_Storage_Session->__construct() #3 /var/www/library/Zend/Auth.php(144): Zend_Auth->getStorage() #4 /var/www/library/Edw/Controller/Plugin/Verify.php(20): Zend_Auth->getIdentity() #5 /var/www/library/Zend/Controller/Plugin/Broker.php(231): Edw_Controller_Plugin_Verify->dispatchLoopStartup(Object(Zend_Controller_Request_Http)) #6 /var/www/library/Zend/Controller/Front.php(863): Zend_Controller_Plugin_Broker->dispatchLoopStartup(Object(Zend_Controller_Request_Http)) #7 /var/www/wwwroot/wwwroot/index.php(110): Zend_Controller_Front->dispatch() #8 {main}
关键词: datasheet 点了 这个 错误
共8条
| 电子价签墨水屏开发被打赏¥35元 | |
