电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Challenge and Response with 1-Wire® SHA
Challenge and Response with 1-Wire® SHA Devices
2012-04-06 20:36:04     打赏
关键词: challenge-response, challenge, random challenge, response, SHA, SHA-1, MAC, coprocessor, user, access control, authentication, ecash, web access, random number generator, DS1963S, DS1961S, DS2432, software piracy
Abstract: Challenge-response can be a secure way of protecting access to any privileged material if implemented correctly. In this document, many options for challenge-response access control are discussed but the most secure method given is presenting a different random challenge on each access attempt and having a response that only the host can interpret without giving out any secrets. This document shows why Maxim’s SHA-1 iButtons® and 1-Wire devices are ideal choices when implementing this kind of challenge-response system.
 Challenge and Response with 1-Wire® SHA Devices.pdf
关键词: Challenge     Response     1-Wire
