电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » White Paper 2: Using the 1-Wire® Public
White Paper 2: Using the 1-Wire® Public Domain Kit
2012-04-06 20:51:52     打赏
关键词: 1-Wire public domain kit, PD, master, public-domain, public domain, open source, C, iButton, DS2480B
Abstract: This document describes how to use the 1-Wire Public Domain (PD) Kit. The kit is a completely open source, portable C library to create a 1-Wire master using the DS2480B serial to 1-Wire line driver or a custom 1-Wire interface. The kit also includes numerous example applications covering a variety of 1-Wire and iButton® devices. This document explains how to combine the files in the kit to form applications on both supported and unsupported operating systems.
  White Paper 2:Using the 1-Wire® Public Domain Kit.pdf
关键词: White     Paper     Using     1-Wire
