电子产品世界 » 论坛首页 » 企业专区 » TI » 【技术应用】RS -485数字电机控制应用
2012-04-11 22:40:29     打赏
摘要:
This application report focuses on the benefits of using RS-485 signaling for motor control and motion control applications. This technology has several benefits for these applications in terms of noise immunity, wide common-mode voltage range, adequate data rate, and multipoint capability. Other applications also use RS-485 signaling to take advantage of these same benefits. Applications such as process control networks, industrial automation, remote terminals, building automation and security systems apply RS-485 extensively to solve their requirements for robust data transmission over relatively long distances.
文档:slla143.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=slla143
关键词: 技术应用     数字     电机     控制     应用
