电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Frequently Asked Questions about Data Co
Frequently Asked Questions about Data Converters
2012-04-12 18:21:59     打赏
关键词: ADC, DAC, analog to digital, digital to analog, convertor, converter, data converter, data convertor, glossary, FAQ, nyquist, charge injection, digital filtering, serial port, I2C, SPI, bit banging, microwire, PC board layout, grounding tips, bypass
Abstract: This article answers most of the common questions regarding data converters. Presented in a classic FAQ format, it addresses topics including: defining an ADC and DAC, and understanding their principal functions; the Nyquist, effects of charge injection; techniques for digital filtering; interfacing to a serial port, I²C interface, and SPI™ interface; bit banging; MICROWIRE interface; PCB (PC-board) layout tips and guidelines; grounding tips; bypass capacitor(s)' effect on performance; debugging ADC accuracy; and debugging noisy measurements.
 Frequently Asked Questions about Data Converters.pdf
关键词: Frequently     Asked     Question
