电子产品世界 » 论坛首页 » 企业专区 » TI » 【技术应用】针对小型尺寸优化的 TPS54620 参考设计
2012-04-21 12:12:59     打赏
摘要:
This reference design contains two different schematics using the TPS54620 DC/DC converter on one print. Both designs accept a 4.5V to 14V input and deliver 6-A at an output voltage of 3.3V while switching at 580 kHz. PMP4854-1 is designed for fast transient response and uses a 3.3uH VLF10045T inductor with two 47uF 1206 ceramic output capacitors. PMP4854-2 is designed to minimize board space. The entire design occupies only 195 square millimeters and uses a 3.3 uH IHLP2525 inductor with only one 47uF 1206 ceramic output capacitor. The TPS54620 is a 4.5 to 17V, 6-A monolithic synchronous buck 1.6 MHz DC/DC converter with integrated 26 / 19 milliohm MOSFETS in a small 3.5mm x 3.5mm 14 pin QFN package.
文档:slvr348 copy.pdf
链接:http://www.ti.com.cn/tool/cn/PMP4854-2
关键词: 技术应用     针对     小型     尺寸     优化     TPS54620
