电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Rail Splitter, from Abraham Lincoln to V
Rail Splitter, from Abraham Lincoln to Virtual Ground
2012-07-02 20:06:57     打赏
关键词: Op Amps, Virtual Ground, Rail Splitter, multiplexer, MUX, voltage divider, sensor conditioning, precision resistor, digital pots, potentiometer, resistance, single power supply, center, matching-bias, reference, channel offset, settling time, error
摘要:铁路分裂是一个人造的虚拟接地作为参考电压。它是用来设置信号匹配运算放大器的“甜蜜点” 。运算放大器具有最线性,无失真的品质,甜蜜点。通常情况下,甜蜜点附近发生单电源轨和地面之间的中心。在信号的情况下,虚拟的地面控制复或开关信号时,通道的DC错误。
 AN4344.pdf
关键词: Splitter     Abraham     Lincoln
