电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » htbadboy-进程贴,数字钟(可调时)
共7条 1/1 1 跳转至页
2013-08-09 22:04:13     打赏
数字钟:有按键消抖,s1键调小时,s2键调分钟,s3键对s清零,另外附带呼吸灯,到59m时开始呼吸,也可以改成倒数8s,led倒计时。
module clock(clk_50m,rstc,keys,sm_seg_out,sm_bit_out,ledbre);
input         clk_50m;                              //50M jing zhen
input         rstc;                                    //fu wei
input  [2:0]  keys;                                //s qing 0:keys[2]; tiao fen :keys[1];tiao shi :keys[0]
//reg    [3:0]  ledcnt;                           //8s  led dao ji shi
output [7:0]  ledbre;                         //led shu chu
reg    [7:0]  ledbre;
reg    [27:0] counter;                       //hu xi deng  zhou qi tiao zheng
reg    [6:0]  PWM_adj;
reg    [7:0]  PWM_width;
reg    [19:0] cnt20ms;                      //ji shi 20ms: jian pan xiao dou
reg    [2:0]  key_samp1;                  //20ms qian jian pan cai yang
reg    [2:0]  key_samp2;                  //20ms hou jian pan cai yang
reg    [2:0]  key_samp1_lock;            //20ms qian cai yang ji cun
reg    [2:0]  key_samp2_lock ;          //20ms hou cai yang ji cun
wire   [2:0]  key_change1;              //pan duan shi fou you an jian an xia
wire   [2:0]  key_change2;             //20ms hou shi fou an jian zhi bian dong
reg    [2:0]  okeys;                       //an jian shu chu
/*************display***************/
output [7:0]  sm_seg_out;                   //shu ma guan duan xuan
output [7:0]  sm_bit_out;                     //wei xuan
reg    [7:0]  sm_seg_out;
reg    [7:0]  sm_bit_out;
reg    [4:0]  dis_dat;                           //shu chu shu zi
reg    [2:0]  dis_loca;                         //shu ma guan cao miao
reg    [3:0]  sec11,min11;                  //s ge wei ,m ge wei
reg    [2:0]  sec12,min12;                   //s shi wei,m shi wei
reg    [3:0]  hou11;
reg    [1:0]  hou12;
parameter     width = 15;                    //1ms ji shi
reg [width:0] cntms;                          //1ms  ji shi
reg   [26:0]  cnt;                                 //1s ji shi
parameter     fre = 4999_9999;           // 1s
/******************jian pan xiao dou kai shi**************************/
always @(posedge clk_50m or negedge rstc)
    if(!rstc)
        key_samp1 <= 3'b111;
    else
        key_samp1 <= keys;                              //dui keys cai yang
    if(!rstc)
        key_samp1_lock <= 3'b111;
    else
        key_samp1_lock <= key_samp1;              //dui keys cai yang zhi ji cun
assign key_change1 = key_samp1_lock & (~key_samp1); //key_change1 pan duan shi fou you an jian an xia
    if(!rstc)
        cnt20ms <= 20'b0;
    else if(key_change1)                                //you an jian  an xia ji dui 20ms ji shu qi qing 0
        cnt20ms <= 20'b0;
        else
            cnt20ms <= cnt20ms + 1'b1;
always @(posedge clk_50m or negedge rstc)   //20ms yan shi hou zai ci cai yang ,yi xia zhu shi tong shi
    if(!rstc)
        key_samp2 <= 3'b111;
    else if(cnt20ms == 20'd100_0000)
        begin
        key_samp2 <= keys;
        end
    if(!rstc)
        key_samp2_lock <= 3'b111;
    else
        key_samp2_lock <= key_samp2;
assign key_change2 = key_samp2_lock & (~key_samp2);// key_change2 = 1 biao shi que shi you an jian an xia
    if(!rstc)
        okeys <= 3'b111;
    else
        okeys <= ~key_change2;                           //fu zhi gei okeys
/*************************jian pan xiao dou jie shu*******************************/
/********************* 1s fen pin*********************/
    begin
    if(!rstc)
           cnt<=1'b0;
    else if(cnt == fre)
           cnt <= 1'b0;
       else
           cnt <= cnt + 1'b1;
    end
/******************* 1ms fen pin ,yong yu shu ma guan sao miao*****************************/
    begin
        if(!rstc)
           cntms<=16'd0;
        else
            begin
                  if(cntms == 16'd49999)
                      cntms <= 16'd0;
                else cntms <= cntms + 1'b1;
             end
    end
/*******************tiao zheng shi zhong*****************************/
    begin
    if(!rstc)
         begin
         sec11 <= 1'b0;
         sec12 <= 1'b0;
         min11 <= 1'b0;
         min12 <= 1'b0;
         hou11 <= 1'b0;
         hou12 <= 1'b0;
         end
    else if(!okeys[2])                               //qing 0
            begin
            sec11 <= 1'b0;
            sec12 <= 1'b0;
            end
    else if(!okeys[1])                                //tiao fen
            begin
            min11 <= min11 + 1'b1;
            if((min11 == 4'b1001)&&(min12 ==3'b101))
                begin
                min11 <= 1'b0;
                min12 <= 1'b0;
                end
            else if(min11 == 4'b1001)
                    begin
                    min11 <= 1'b0;
                    min12 <= min12 + 1'b1;
                    end
            end
    else if(!okeys[0])                               //tiao shi
        begin
        hou11 <= hou11 +1'b1;
            if((hou11 == 4'b0011)&&(hou12 == 2'b10))
                begin
                hou11 <= 1'b0;
                hou12 <= 1'b0;
                end
            else if(hou11 == 4'b1001)
                begin
                hou11 <= 1'b0;
                hou12 <= hou12 + 1'b1;
                end
        end
///////////////////zheng chang ji shi/////////////////////
    else if(cnt == fre)
            begin
            if(sec11 == 4'd9)                /****************??sec11????????******************/
                begin
                sec11 <= 1'b0;
                if(sec12 ==3'd5)              /**************??sec12????????*****************/
                    begin
                    sec12 <= 1'b0;
                    if(min11 == 4'd9)               /****************??min11*************************/
                        begin
                        min11 <= 1'b0;
                        if(min12 == 3'd5)         /**********??min12**************/
                            begin
                            min12 <= 1'b0;
                            if(hou11 == 4'd9)          /****??hou11*****/
                                begin
                                hou11 <= 1'b0;
                                end
                            else
                                begin
                                if((hou12 == 2'd2)&&(hou11 == 4'd3))
                                    begin
                                    hou11 <= 1'b0;
                                    hou12 <= 1'b0;
                                    end
                                else
                                    begin
                                    hou11 <= hou11 + 1'b1;
                                    hou12 <= hou12;
                                    end                           /*hhhhhhhhhhhhhhhhhhhhhh*/
                                end
                            end
                        else min12 <= min12 +1'b1 ;        /**********min12**************/
                        end
                    else min11 <= min11+1'b1;           /*mmmmmmmmmm11mmmmmmmmm*/
                    end
                else sec12 <= sec12+1'b1 ;            /**************sec12*****************/
                end
            else sec11 <= sec11+1'b1;            /****************sec11******************/
            end
        else  //wei dao 1s ji xu bao chi
            begin
            sec11 <= sec11;
            sec12 <= sec12;
            min11 <= min11;
            min12 <= min12;
            hou11 <= hou11;
            hou12 <= hou12;
            end
    end
//////////////display/////////////////
always @(posedge clk_50m or negedge rstc)                       //1ms
    begin
        if(!rstc)
           dis_loca <= 3'd0;
        else
            begin
                  if(cntms == 49999)
                    if(dis_loca == 3'b111)
                        dis_loca <= 3'b000;
                    else
                          dis_loca <= dis_loca + 1'b1;
                  else dis_loca <= dis_loca;
            end
    end
always @(dis_loca)
    case(dis_loca)
        3'b000 : sm_bit_out = 8'b1111_1110;
        3'b001 : sm_bit_out = 8'b1111_1101;
        3'b010 : sm_bit_out = 8'b1111_1011;
        3'b011 : sm_bit_out = 8'b1111_0111;
        3'b100 : sm_bit_out = 8'b1110_1111;
        3'b101 : sm_bit_out = 8'b1101_1111;
        3'b110 : sm_bit_out = 8'b1011_1111;
        3'b111 : sm_bit_out = 8'b0111_1111;
        default : sm_bit_out = 8'b1111_1111;
    endcase
always @(sm_bit_out or sec11 or sec12 or min11 or min12 or hou11 or hou12)
    case(sm_bit_out)
        8'b1111_1110 : dis_dat = sec11;                   //s ge wei
        8'b1111_1101 : dis_dat = sec12;
        8'b1111_1011 : dis_dat = 4'b1010;
        8'b1111_0111 : dis_dat = min11;                 //m ge wei
        8'b1110_1111 : dis_dat = min12;
        8'b1101_1111 : dis_dat = 4'b1010;
        8'b1011_1111 : dis_dat = hou11;                   //h ge wei
        8'b0111_1111 : dis_dat = hou12;
        default      : dis_dat = 4'b1011;
    endcase
always @(dis_dat)
    case(dis_dat)
        4'b0000 : sm_seg_out = 8'hc0;              //0
        4'b0001 : sm_seg_out = 8'hf9;              //1
        4'b0010 : sm_seg_out = 8'ha4;             //2
        4'b0011 : sm_seg_out = 8'hb0;              //3
        4'b0100 : sm_seg_out = 8'h99;              //4
        4'b0101 : sm_seg_out = 8'h92;                  //5
        4'b0110 : sm_seg_out = 8'h82;           //6
        4'b0111 : sm_seg_out = 8'hf8;           //7
        4'b1000 : sm_seg_out = 8'h80;          //8
        4'b1001 : sm_seg_out = 8'h90;           //9
        4'b1010 : sm_seg_out = 8'hbf;            //-
        4'b1011 : sm_seg_out = 8'hff;          //null  shu ma guan quan mie ,ju shi yan zhe neng xiao chu
shu ma guan xian shi de can ying
        default : sm_seg_out = 8'hff;          //null  shu ma guan quan mie ,ju shi yan zhe neng xiao chu shu ma guan xian shi de can ying
    endcase
always @(posedge clk_50m or negedge rstc)        //hu xi deng  1m dao ji shi huo zhe shi 8s dao ji shi
        begin
           if(!rstc)
             begin
//               counter <= 0;                       //8s led dao ji shi
                 ledbre <= 8'b1111_1111;
             end
           else
                /*begin
                if((cnt == fre)&&(min11 == 4'd9)&&(min12 == 3'd5)&&((sec11 <= 4'd9)&&(sec12 == 3'd5)&&(sec11 >= 4'd1)))
                    begin
                    if(ledcnt == 4'b1000)
                        ledcnt <= 4'b0;
                    else
                    ledcnt <= ledcnt + 1'b1;
                    end
                else
                    case(ledcnt)
                    4'b0000 : ledbre <= 8'b1111_1111;
                    4'b0001 : ledbre <= 8'b0000_0000;
                    4'b0010 : ledbre <= 8'b0000_0001;
                    4'b0011 : ledbre <= 8'b0000_0011;
                    4'b0100 : ledbre <= 8'b0000_0111;
                    4'b0101 : ledbre <= 8'b0000_1111;
                    4'b0110 : ledbre <= 8'b0001_1111;
                    4'b0111 : ledbre <= 8'b0011_1111;
                    4'b1000 : ledbre <= 8'b0111_1111;
                    default : ledbre <= 8'b1111_1111;
                endcase
                end*/
                begin
                     counter   <= counter + 1'b1;
                     PWM_width <= PWM_width[6:0]+ PWM_adj;
                     if(counter[27])
                        PWM_adj <= counter[26:20];              //128 zhong liang du,mei zhong chi xu shi jian 2 de 20 ci fang ge ji shu
                     else
                        PWM_adj <= ~ counter[26:20];
                    if((min11 == 4'd9)&&(min12 == 3'd5))
                        begin
                         ledbre[0] <= PWM_width[7];
                         ledbre[1] <= PWM_width[7];
                         ledbre[2] <= PWM_width[7];
                         ledbre[3] <= PWM_width[7];
                         ledbre[4] <= PWM_width[7];
                         ledbre[5] <= PWM_width[7];
                         ledbre[6] <= PWM_width[7];
                         ledbre[7] <= PWM_width[7];
                         end
                    else ledbre <= 8'b1111_1111;
                end
         end
endmodule
有个很严重的问题:
    这款入门级CPLD芯片居然只有240个逻辑资源,严重不足啊。在公司电脑(32位Xp)上编译(好像是quartus ii 6.0还是什么),共占用235个,回来用自己的电脑(win7 64位)quartus ii v10.0上编译,占用245个,逻辑资源不够了,什么情况?
    本来来有中文注释的,,但是上面中文乱码了,变成?了,改成拼音了,我把源文件传上来。clock_h.zip
乱码貌似是quartus版本问题,用公司电脑打开是正常显示的,在quartusii 10.0里变成?了。上网查了下,说从
7.0之后就不支持中文了,
关键词: CPLD     FPGA     verilog     数字钟
2013-08-10 23:08:28     打赏
把你呼吸灯部分去掉,就可以了
我移植到我的板子上,去掉呼吸灯就可以了
2013-08-11 09:11:33     打赏
那为毛32位XP就可以呢
2013-08-11 11:52:15     打赏
不知道哦,不去呼吸灯的时候,说需要248个逻辑模块,编译报错
2013-08-11 18:07:03     打赏
当年的cpld!实验就是这个,不过是逻辑器件画
2013-08-11 19:07:21     打赏
吼吼,用逻辑图的形式做这个,赶脚很麻烦。
2013-08-21 10:07:09     打赏
7楼
不错,加油继续!
共7条 1/1 1 跳转至页
