电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » 欧洲晶体管BUxxx 系列晶体管参数大全
2014-06-12 10:38:00     打赏
型号材料最高电压最大电流最大功率频率沟道电阻
BUX10SI-NPN160 V25 A150 W1,5 us-
BUZ10N-FET50 V20 A80 W-0,08 Ohm
BUT11ASI-NPN1000 V5 A100 W0,8 us-
BUT11AFSI-NPN1500 V5 A20 W0,8 us-
BUW11ASI-NPN1000 V5 A100 W0,8 us-
BUW11AFSI-NPN1000 V5 A32 W0,8 us-
BUZ11N-FET50 V36 A---
BUZ11AN-FET50 V27 A90 W-0,055 Ohm
BUT12ASI-NPN1000 V8 A125 W0,8 us-
BUT12AFSI-NPN1000 V8 A23 W0,8 us-
BUW12SI-NPN850 V8 A125 W0,8 us-
BUW12ASI-NPN1000 V8 A125 W0,8 us-
BUW12FSI-NPN850 V8 A34 W0,8 us-
BUX12SI-NPN300 V20 A150 W--
BUT13N-DARL+D400 V28 A175 W--
BUW13SI-NPN850 V15 A175 W0,8 us-
BUW13ASI-NPN1000 V15 A175 W0,8 us-
BUX13SI-NPN400 V15 A150 W8 MHz-
BUS14ASI-NPN450 V30 A250 W--
BUZ14N-FET50 V39 A125 W--
BUZ15N-FET50 V45 A125 W--
BUT18ASI-NPN450 V6 A110 W--
BUT18AFSI-NPN1000 V6 A33 W0,8 us-
BUV18SI-NPN120 V47 A250 W1,5 us-
BUY18SSI-NPN40 V10 A20 W--
BUV20SI-NPN160 V50 A250 W1,5 us-
BUX20SI-NPN160 V50 A350 W1,5 us-
BUV21SI-NPN200 V40 A250 W--
BUZ21N-FET100 V21 A---
BUX22SI-NPN300 V40 A250 W--
BUZ22N-FET100 V34 A125 W-0,055 Ohm
BUS23SI-NPN300 V15 A175 W--
BUV23SI-NPN325 V40 A250 W--
BUW23SI-PNP450 V10 A125 W--
BUX23SI-NPN325 V30 A350 W--
BUV24SI-NPN400 V30 A250 W--
BUX24SI-NPN400 V20 A350 W--
BUV25SI-NPN500 V20 A250 W--
BUV26SI-NPN180 V14 A85 W1,8 us-
BUV26ASI-NPN200 V20 A85 W--
BUW26SI-NPN800 V10 A125 W20 MHz-
BUV27SI-NPN240 V12 A65 W--
BUV28SI-NPN400 V10 A65 W--
BUV28ASI-NPN450 V10 A65 W--
BUT30VSI-NPN125 V100 A250 W--
BUZ30AN-FET200 V7 A75 W--
BUX32BSI-NPN1000 V8 A150 W--
BUT34N-DARL+D850 V50 A250 W--
BUX37N-DARL400 V15 A35 W--
BUX39SI-NPN90 V30 A120 W8 MHz-
BUX40SI-NPN160 V20 A120 W1,2 us-
BUX41SI-NPN250 V15 A120 W--
BUX41NPNSI-NPN160 V18 A120 W--
BUW42SI-PNP400 V15 A150 W--
BUX42SI-NPN300 V12 A120 W--
BUL45SI-NPN400 V5 A75 W12 MHz-
BUV46ASI-NPN450 V6 A85 W--
BUY47SI-NPN120 V7 A10 W90 MHz-
BUS48ASI-NPN1000 V15 A175 W--
BUS48APNPSI-NPN1000 V15 A125 W--
BUV48ASI-NPN1000 V15 A150 W0,8 us-
BUV48AFSI-NPN1000 V15 A65 W--
BUV48CSI-NPN700 V15 A150 W--
BUV48CFSI-NPN1200 V15 A65 W--
BUW48SI-NPN120 V30 A150 W1,5 us-
BUX48ASI-NPN1000 V15 A175 W0,8 us-
BUW49SI-NPN160 V30 A150 W--
BUY49PNPSI-NPN250 V3 A10 W--
BUY49SSI-NPN250 V3 A10 W50 MHz-
BUV50SI-NPN250 V25 A150 W--
BUW50SI-NPN250 V25 A150 W--
BUZ50AN-FET1000 V2,5 A75 W-5 Ohm
BUR51SI-NPN200 V60 A350 W--
BUX51SI-NPN200 V3,5 A10 W--
BUR52SI-NPN250 V60 A350 W--
BUL54ASI-NPN1000 V4 A65 W20 MHz-
BUX54SI-NPN450 V2 A10 W8 MHz-
BUX55SI-NPN450 V2 A10 W8 MHz-
BUT56ASI-NPN1000 V8 A100 W--
BUV56ASI-NPN1000 V10 A70 W--
BUT57N-DARL+D400 V15 A110 W--
BUV61SI-NPN300 V50 A250 W--
BUX66SI-PNP150 V2 A35 W20 MHz-
BUY69ASI-NPN1000 V10 A100 W1 us-
BUT70SI-NPN200 V40 A200 W--
BUV70SI-NPN550 V10 A140 W--
BUY70ASI-NPN400 V10 A75 W--
BUY71SI-NPN2200 V2 A40 W--
BUZ71N-FET50 V18 A80 W-0,1 Ohm
BUZ71AFN-FET50 V11 A35 W-0,12 Ohm
BUT72SI-NPN400 V40 A200 W--
BUW72SI-NPN450 V10 A100 W--
BUY72SI-NPN200 V10 A60 W--
BUZ72AN-FET100 V11 A---
BUZ72AFN-FET100 V10 A40 W--
BUZ73N-FET200 V7 A40 W-0,4 Ohm
BUZ73AN-FET200 V5,8 A40 W-0,6 Ohm
BUT76ASI-NPN1000 V10 A100 W0,8 us-
BUX77SI-NPN100 V5 A40 W2,5 MHz-
BUX80SI-NPN800 V10 A100 W--
BUW81AN-DARL800 V10 A80 W--
BUX81SI-NPN1000 V10 A100 W--
BUX82SI-NPN800 V6 A60 W--
BUW84SI-NPN800 V2 A50 W0,4 us-
BUX84SI-NPN800 V2 A40 W0,4 us-
BUW85SI-NPN1000 V2 A50 W0,4 us-
BUX85SI-NPN1000 V2 A40 W0,4 us-
BUX85FSI-NPN1000 V2 A18 W0,4 us-
BUX86SI-NPN800 V0,5 A20 W0,4 us-
BUX87SI-NPN1000 V0,5 A20 W0,4 us-
BUX88SI-NPN1500 V12 A160 W7 MHz-
BUY89SI-NPN1500 V6 A80 W--
BUT90SI-NPN200 V50 A250 W--
BUV90N-DARL+D650 V10 A125 W--
BUZ90N-FET600 V4,5 A70 W-1,6 Ohm
BUZ90AN-FET600 V4 A75 W-2,0 Ohm
BUZ90AFN-FET600 V4,3 A75 W--
BUZ91AN-FET600 V8 A150 W-0,9 Ohm
BUT92SI-NPN250 V50 A250 W--
BUT93SI-NPN600 V4 A55 W9 MHz-
BUV93SI-NPN350 V2 A15 W12 MHz-
BUZ93N-FET600 V3,6 A80 W-2,5 Ohm
BUS98ASI-NPN450 V30 A250 W--
BUV98ASI-NPN1000 V30 A150 W5 MHz-
BUX98ASI-NPN450 V30 A250 W--
BUX98CSI-NPN1200 V30 A250 W5 MHz-
BUZ100N-FET50 V60 A250 W-0,18 Ohm
BU106SI-NPN325 V10 A50 W--
BU107SI-NPN300 V10 A50 W--
BU109SI-NPN330 V10 A85 W--
BU110SI-NPN150 V10 A30 W15 MHz-
BU124ASI-NPN400 V10 A50 W6 MHz-
BU125SI-NPN60 V5 A0,8 W100 MHz-
BU128SI-NPN200 V10 A62 W--
BU133SI-NPN250 V3 A30 W--
BUZ171P-FET50 V8 A40 W-0,3 Ohm
BU180ASI-N+D400 V10 A---
BU180EN-DARL1500 V5 A12 W--
BU189N-DARL330 V8 A60 W--
BU208ASI-NPN1500 V8 A150 W--
BU208BSI-NPN700 V5 A80 W7 MHz-
BU208DSI-N+D1500 V8 A150 W--
BU209SI-NPN1700 V4 A12,5 W--
BUZ215N-FET500 V5 A75 W-1,5 Ohm
BU226SI-NPN2000 V1,5 A10 W--
BUL310SI-NPN1000 V5 A75 W0,4 us-
BUL310PISI-NPN1000 V5 A35 W0,4 us-
BUZ310N-FET1000 V2,5 A75 W-5 Ohm
BU312SI-NPN150 V6 A25 W--
BUH315SI-NPN1500 V5 A50 W--
BUH315DSI-N+D700 V5 A50 W--
BU325SI-NPN200 V3 A25 W--
BUZ325N-FET400 V12,5 A125 W-0,3 Ohm
BU326ASI-NPN900 V6 A75 W--
BU326S-RFTSI-NPN400 V6 A60 W--
BUZ326N-FET400 V10,5 A125 W--
BUZ330N-FET500 V9,5 A125 W-0,6 Ohm
BUZ332N-FET600 V8,5 A150 W-0,8 Ohm
BUZ332AN-FET600 V8 A150 W-0,9 Ohm
BUZ338N-FET500 V13,5 A180 W-0,4 Ohm
BUZ341N-FET200 V
关键词: 欧洲晶体     参数大全
