电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 树莓派读取温湿度传感器DHT11
树莓派读取温湿度传感器DHT11
2014-07-30 12:36:23     打赏
硬件:
树莓派 2.0
DHT模块  接树莓派5V GND GPIO1
功能:读取传感器数据并打印出来
  1. //
  2. //mydht11.c
  3. //
  4. #include <wiringPi.h>
  5. #include <stdio.h>
  6. #include <stdlib.h>
  7.
  8. typedef unsigned char uint8;
  9. typedef unsigned int  uint16;
  10. typedef unsigned long uint32;
  11.
  12. #define HIGH_TIME 32
  13.
  14. int pinNumber =1;  //use gpio1 to read data
  15. uint32 databuf;
  16.
  17.
  18.
  19. uint8 readSensorData(void)
  20. {
  21.     uint8 crc;
  22.     uint8 i;
  23.
  24.     pinMode(pinNumber,OUTPUT); // set mode to output
  25.     digitalWrite(pinNumber, 0); // output a high level
  26.     delay(25);
  27.     digitalWrite(pinNumber, 1); // output a low level
  28.     pinMode(pinNumber, INPUT); // set mode to input
  29.     pullUpDnControl(pinNumber,PUD_UP);
  30.
  31.     delayMicroseconds(27);
  32.     if(digitalRead(pinNumber)==0) //SENSOR ANS
  33.        {
  34.          while(!digitalRead(pinNumber)); //wait to high
  35.
  36.       for(i=0;i<32;i++)
  37.        {
  38.        while(digitalRead(pinNumber)); //data clock start
  39.        while(!digitalRead(pinNumber)); //data start
  40.           delayMicroseconds(HIGH_TIME);
  41.           databuf*=2;
  42.            if(digitalRead(pinNumber)==1) //1
  43.            {
  44.                 databuf++;
  45.            }
  46.         }
  47.
  48.       for(i=0;i<8;i++)
  49.        {
  50.        while(digitalRead(pinNumber)); //data clock start
  51.        while(!digitalRead(pinNumber)); //data start
  52.           delayMicroseconds(HIGH_TIME);
  53.           crc*=2;
  54.           if(digitalRead(pinNumber)==1) //1
  55.            {
  56.                 crc++;
  57.            }
  58.         }
  59.     return 1;
  60.        }
  61.    else
  62.         {
  63.         return 0;
  64.          }
  65. }
  66.
  67. int main (void)
  68. {
  69.
  70.   printf("Use GPIO1 to read data!\n");
  71.
  72.   if (-1 == wiringPiSetup()) {
  73.     printf("Setup wiringPi failed!");
  74.     return 1;
  75.   }
  76.
  77.   pinMode(pinNumber, OUTPUT); // set mode to output
  78.   digitalWrite(pinNumber, 1); // output a high level
  79.
  80.   printf("Enter OS-------\n");
  81.   while(1) {
  82.     pinMode(pinNumber,OUTPUT); // set mode to output
  83.     digitalWrite(pinNumber, 1); // output a high level
  84.     delay(3000);
  85.     if(readSensorData())
  86.     {
  87.        printf("Congratulations ! Sensor data read ok!\n");
  88.        printf("RH:%d.%d\n",(databuf>>24)&0xff,(databuf>>16)&0xff);
  89.        printf("TMP:%d.%d\n",(databuf>>8)&0xff,databuf&0xff);
  90.        databuf=0;
  91.      }
  92.     else
  93.      {
  94.         printf("Sorry! Sensor dosent ans!\n");
  95.        databuf=0;
  96.       }
  97.   }
  98.   return 0;
  99. }
