电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » ATmega16简单计算器主程序
ATmega16简单计算器主程序
2014-10-05 20:31:03     打赏
能实现加减乘除运算,不带小数点,最大能计算到65535,溢出则出现错误。
void main(void)
uchar i;
CLI(); //关中断
Port_Init();    //端口初始化
Timer0_Init(); //定时器初始化
Keyboard_Init(); //键盘板初始化
SEI(); //开中断
   first=0;second=0;result=0;op=0;Cnt_flag=1;Dis_flag=1;TM1721_Dis_Num(0,0);
while(1)
if(timer_50ms_fg==1) //50ms扫描一次键盘
   timer_50ms_fg=0;
   i=TM1721_Key_Scan();
   Key_Process(i);
*功    能:键盘处理
*入口参数:按键值
void Key_Process(uchar keycode)
if(keycode!=keycode_old)
if((keycode<10)&&(Cnt_flag==1))   //数字"0~9"
    first=(first*10+keycode);
    Dis_flag=1;
    TM1721_Dis_Num(first,0);
   if(Dis_flag==1) TM1721_Dis_Num(first,0);
    if((keycode>11)&&(keycode<16))       //"+","-","*","/"
      op=keycode;
      Dis_flag=2;
      Cnt_flag=2;
     if((keycode)<10&&(Cnt_flag==2))    //数字"0~9"
        second=second*10+keycode;
        Dis_flag=3;
        TM1721_Dis_Num(second,0);
        if(Dis_flag==3) TM1721_Dis_Num(second,0);
        if(keycode==11)           //"="
             switch(op)       //op="+","-","*","/"
              case 12: result=first+second; break;
                case 13: result=first-second; break;
               case 14: result=first*second; break;
                case 15: result=first/second; break;
             TM1721_Dis_Num(result,0);
             Dis_flag=4;
             Cnt_flag=1;
           if(Dis_flag==4) TM1721_Dis_Num(result,0);
            if(keycode==16)
             { first=0;second=0;result=0;op=0;Cnt_flag=1;Dis_flag=1;TM1721_Dis_Num(0,0);}
keycode_old=keycode;   //将新的键盘码存到老的键盘码中
