InputMode = comInputModeBinary
RThreshold = 0
SThreshold = 0
Private Sub TmrComm_Timer()
'采用轮循法采集数据
Dim Rx_buff() As Byte
Dim okstring As String
Dim ReceivedLen As Integer
On Error GoTo ErrorHandler
TmrComm.Enabled = False '关闭定时器
If commport.InBufferCount > 0 Then
ReceivedLen = commport.InBufferCount
Rx_buff = commport.Input
okstring = StrConv(tempbyte, vbUnicode)
If ReceivedLen = 6 Then
If Chr(tempbyte(0)) = ":" And tempbyte(3) = &h0a Then
End If
If Instr(okstring ,"
End If
End If
TmrComm.Enabled = True '打开定时器
End Sub
