电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » EDA
EDA
2014-10-30 22:14:36     打赏
5  条件赋值语句
LRBRAR   IEEE;
USE  IEEE.STD_LOGIC_1164.ALL;
ENTITY  YMQ3to8 IS
PORT  (  DIN: IN  STD_LOGIC_VETOR(2 DOWNTO 0;
DOUT : OUT  BIT_VECTOR(7 DOWNTO 0);
END  YMQ38;
ARCHITECTURE BHV OF YMQ38 IS
BEGIN
 PROCESS(DIN)
BEGIN
  WITH CONV_TNTEGER(DIN)  SECLET
  DOUT<=”00000001”WHEN 0,
         ”00000010”WHEN 1,
         ”00000100”WHEN2,
         ”00001000”WHEN3,
         ”00010000”WHEN4,
         ”00100000”WHEN5,
         ”01000000”WHEN6
         ”10000000”WHEN 7,
NAFFECTED WHEN OTHERS;
END BHV
IF_ELSE语句
LRBRAR   IEEE;
ENTITY  YMQ3to8 IS
END  YMQ38;
BEGIN
IF   CON_INTEGER(DIN)=0 THEN DOUT<=”00000001”;
ELSIF CON_INTEGER(DIN)=1 THEN DOUT<=”00000010”
ELSIF CON_INTEGER(DIN)=2 THEN DOUT<=”00000100”
ELSIF CON_INTEGER(DIN)=3 THEN DOUT<=”00001000”
ELSIF CON_INTEGER(DIN)=4 THEN DOUT<=”00010000”
ELSIF CON_INTEGER(DIN)=5 THEN DOUT<=”00100000”
ELSIF CON_INTEGER(DIN)=6 THEN DOUT<=”01000000”
ELSIF CON_INTEGER(DIN)=7THEN DOUT<=”10000000”
END IF;
END PROCESS;
END BHV
 CASE语句
LRBRAR   IEEE;
ENTITY  YMQ3to8 IS
END  YMQ38;
BEGIN
 PROCESS(DIN)
BEGIN
  CASE CONV_TNTEGER(DIN) IS
WHEN 0=>DOUT<=”00000001”;
WHEN 1=>DOUT<=”00000010”;
WHEN2=>DOUT<=”00000100”;
WHEN 3=>DOUT<=”00001000”;
WHEN 4=>DOUT<=”00010000”;
WHEN 5=>DOUT<=”00100000”;
WHEN 6=>DOUT<=”01000000”;
WHEN 7=>DOUT<=”10000000”;
WHEN OTHERS =>NULL
END  CASE;
移位操作
LRBRAR   IEEE;
ENTITY  YMQ3to8 IS
END  YMQ38;
BEGIN
  DOUT<=”00000001” SLL CONV_INTEGR(DIN);
END BHV
条件赋值语句
LRBRAR   IEEE;
ENTITY  YMQ3to8 IS
END  YMQ38;
BEGIN
 PROCESS(DIN)
BEGIN
         ”00000010”WHEN 1,
         ”00000100”WHEN2,
         ”00001000”WHEN3,
         ”00010000”WHEN4,
         ”00100000”WHEN5,
         ”01000000”WHEN6
         ”10000000”WHEN 7,
END BHV
IF_ELSE语句
LRBRAR   IEEE;
ENTITY  YMQ3to8 IS
END  YMQ38;
BEGIN
END IF;
END PROCESS;
END BHV
15
LRBRAR   IEEE;
ENTITY  BJQ7 IS
PORT  (INPUT:    IN    STD_LOGIC_VECTOR(6 DOWNTO 0;
       OUTPUT:   OUT  STD_LOGIC_VECTOR(2 DOWNTO 0);
       Y:         OUT     STD_LOGIC;
END  BJQ7;
ARCHITECTURE  BHV  OF BJQ7  IS
BEGIN
PROCESS(INPUT)
VARIABLE  Q : STD_LOGIC_VECTOR(2DOWNTO 0);
BEGIN
Q :=”000”;
FOR n in  0  TO  6  LOOP
  IF (INPUT(n)=’1’)  THEN Q:=Q+1;
 END IF;
END  LOOP;
OUTPUT<=Q;
IF (OUTPUT>=4)  Y<=’1’  ELSE Y<=’0’;
END  IF;
END PROCESS
