电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » 第四次作业
第四次作业
2014-11-13 21:40:48     打赏
3-3
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY mux 41 IS
PORT (a,b,c,d:IN STD_LOGIC;
S0: IN STD_LOGIC;
S1: IN STD_LOGIC;
y: OUT STD_LOGIC);
END ENTITY mux 41;
ARCHITECTURE case_mux41 OF mux41 IS
SIGNAL.s0s1 :STD_LOGIC_VECTOR(1 DOWNTO 0);
BEGIN
s0s1<=s1&s0;
PROCESS(s0s1,a,b,c,d)
BEGIN
CASE s0s1 IS
WHEN "00"
WHEN "01"
WHEN "10"
WHEN "11"
WHEN OTHERS
END CASE;
END PROCESS;
END ARCHITECTURE case_mux41;
3-4
(1)
LIBRARY IEEE;
ENTITY f_suber IS
PORT(x,y,sub_in: IN STD_LOGIC;
sub_out,diff_out: OUT STD_LOGIC);
END ENTITY f_suber;
ARCHITECTURE fs1 OF f_suber IS
COMPONENT h_suber
PORT(x,y: IN STD_LOGIC;
diff,s_out:OUT STD_LOGIC);
END COMPONENT;
SIGNAL a,b,c:STD_LOGIC;
BEGIN
u1: h_suber PORT MAP(x=>xin,y=>yin, diff=>a, s_out=>b);
u2: h_suber PORT MAP(x=>a, y=>sub_in,diff=>diff_out,s_out=>c);
sub_out <=c OR b;
END ARCHITECTURE fs1;
(2)图在附件里
程序
LIBRARY IEEE;
ENTITY suber_8 IS
PORT (x0,x1,x2,x3,x4,x5,x6,x7: IN STD_LOGIC;
y0,y1,y2,y3,y4,y5,y6,y7,sin: IN STD_LOGIC;
diff0,diff1,diff2,diff3: OUT STD _LOGIC;
diff4,diff5,fiff6,diff7,sout: OUT STD_LOGIC );
END ENTITY suber_8;
ARCHITECTURE s8 OF suber_8 IS
COMPONENT f_suber
PORT(xin,yin,sub_in: IN STD_LOGIC;
END COMPONENT;
SIGNAL a0,a1,a2,a3,a4,a5,a6: STD_LOGIC;
BEGIN
u0: f_suber PORT MAP(xin=>x0,yin=>y0,diff_out=>diff0,sub_in=>sin,sub_out=>a0);
u1: f_suber PORT MAP(xin=>x1,yin=>y1,diff_out=>diff1,sub_in=>a0,sub_out=>a1);
u2: f_suber PORT MAP(xin=>x2,yin=>y2,diff_out=>diff2,sub_in=>a1,sub_out=>a2);
u3: f_suber PORT MAP(xin=>x3,yin=>y3,diff_out=>diff3,sub_in=>a2,sub_out=>a3);
u4: f_suber PORT MAP(xin=>x4,yin=>y4,diff_out=>diff4,sub_in=>a3,sub_out=>a4);
u5: f_suber PORT MAP(xin=>x5,yin=>y5,diff_out=>diff5,sub_in=>a4,sub_out=>a5);
u6: f_suber PORT MAP(xin=>x6,yin=>y6,diff_out=>diff6,sub_in=>a5,sub_out=>a6);
u7: f_suber PORT MAP(xin=>x7,yin=>y7,diff_out=>diff7,sub_in=>a6,sub_out=>sout);
END ARCHITECTURE s8;
