电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » 第七次作业
第七次作业
2014-12-15 23:25:36     打赏
5-1.
同步复位和异步复位。同步复位是指与 时钟同步 ,当复位信号有效之后,出现时钟有效边沿时才对电路模块进行复位操作;而异步复位与 时钟信号 无关,只要复位信号有效,无论这时时钟信号是什么样,都对电路模块进行复位操作。
同步复位 D触发器 :
IF clock'event AND clock='1' THEN
IF reset_n='0' THEN q <= (OTHERS => '0');
ELSE q <= d;
END IF;
END IF;
异步复位D触发器:
ELSIF clock'event AND clock='1' THEN q <= d;
END IF;
5-7.
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY CNT10 IS
PORT(CLK,RST,EN,LOAD : IN STD_LOGIC;
DATA : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
DOUT : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
COUT : OUT STD_LOGIC);
ARCHITECTURE behav OF CNT10 IS
BEGIN
PROCESS(CLK,RST,EN,LOAD)
VARIABLE Q : STD_LOGIC_VECTOR(3 DOWNTO 0);
BEGIN
IF RST='0' THEN Q:=(OTHERS =>'0');
ELSIF CLK'EVENT AND CLK='1' THEN
IF EN='1' THEN
IF LOAD='0' THEN Q:=DATA;
ELSE
IF Q<9 THEN Q:=Q+1;
ELSE Q:=(OTHERS=>'0');
END IF;
END IF;
END IF;
END IF;
IF Q=9 THEN COUT<='1';
ELSE COUT<='0';
END IF;
DOUT<=Q;
END PROCESS;
5-8.
LIBRARY IEEE;
ENTITY ADD_SUB_LOAD_16 IS
PORT (CLK,RST,ADD_EN,SUB_EN,LOAD : IN STD_LOGIC;
DATA:IN STD_LOGIC_VECTOR(15 DOWNTO 0) ;
CQ : OUT STD_LOGIC_VECTOR(15 DOWNTO 0) ;
COUT:OUTSTD_LOGIC);
EN D ENTITY ADD_SUB_LOAD_16;
ARCHITECTUREA_S_16OFADD_SUB_LOAD_16IS
BEGIN
PROCESS(CLK,RST,ADD_EN,SUB_EN,LOAD)
VARIABLECQI:STD_LOGIC_VECTOR(15DOWNTO0);
VARIABLELS_LOAD:
STD_LOGIC;
BEGINLS_LOAD:=LOAD;
IFRST='1'THENCQI:=(OTHERS=>'0');
ELSIF LOAD='1'THENCQI:=DATA;--LS_LOAD:='0';
ELSIF CLK'EVENTANDCLK='1'THEN
IF ADD_EN='1'THEN
IF CQI<16#FFFF#THECQI:=CQI+1;
ELSE CQI:=(OTHERS=>'0');
EN D IF;
I F CQI=16#FFFF#THENCOUT<='1';
ELSE COUT<='0';
END IF;
END IF;
IF SUB_EN='1'THEN
IF CQI>0 THEN CQI:=CQI-1;
ELSE CQI:=(OTHERS => '1');
END IF;
IF CQI=0 THEN COUT<='1';
IF CQI=0THENCOUT<='1';
CQ<=CQI;
ENDPROCESS;
END ARCHITECTURE A_S_16;
