电子产品世界 » 论坛首页 » 企业专区 » GD32 » [GD32130C-START]GD32F130C8真的可以兼容ST的吗?(十)
[GD32130C-START]GD32F130C8真的可以兼容ST的吗?(十)SPI DMA发送实验
2015-04-11 10:24:47     打赏
在前一个实验中,我们使用了SPI发送功能,但是在实例中,程序是设计为查询的方式来发送数据。查询的方式在早期应用中,广泛使用,但是随着科技的进步,传说中的DMA方式已经容入普通低成本的控制器中,例如我们的主角GD32F130C8。今天带给大家的实验就是通过DMA方式来发送我们图形缓冲区里的数据。
这个是我们定义的图形缓冲区数组:
extern uint8_t GrBuf[8][128];
下面我们再次配置SPI1外设,参考源代码如下:
void LEDPIN_Init(void)    //初始化引脚口,请在OLED进行修改你所对应的引脚,均为普通脚输出
  GPIO_InitTypeDef GPIO_InitStructure;
  SPI_InitTypeDef  SPI_InitStructure;
  DMA_InitTypeDef  DMA_InitStructure;
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
  OLED_RST();
  OLED_SELECT();
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7;
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource5, GPIO_AF_0);
  GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_0);
  /* SPI configuration -------------------------------------------------------*/
  SPI_I2S_DeInit(SPI1);
  SPI_InitStructure.SPI_Direction = SPI_Direction_1Line_Tx;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_Init(SPI1, &SPI_InitStructure);
  SPI_RxFIFOThresholdConfig(SPI1, SPI_RxFIFOThreshold_HF);
  SPI_Cmd(SPI1, ENABLE);
  /* DMA Configuration -------------------------------------------------------*/
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize =  DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_InitStructure.DMA_BufferSize = (uint16_t)1024;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)SPI1_DR_ADDRESS;
  DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t) &GrBuf[0][0];
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_Init(DMA1_Channel3, &DMA_InitStructure);
  DMA_Cmd(DMA1_Channel3, ENABLE);
  SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, DISABLE);
具体配置内容大家可以对比参考官方示例内的SPI接收DMA方式。
这个就是刷屏后的演示~~
截止到本例,我们已经发布了10期GD32与stm32的对比实验,可见版主使用IAR编译环境与ST官方库是完全兼容GD32F130C8.在接下来的日子里,版主将会与大家分享Stellaris图形库的使用与RS485通讯。
还望网友多多期待^_^
关键词: GD32130C-START     兆易     GD32F13
2015-04-23 09:30:55     打赏
gd能用st的库函数?
