-- Engineer: skycanny
-- Module Name: fulladder - Behavioral
-- Tool versions: ISE 7.1
-- Description: This module is designed to discribe a full adder with carry
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity fulladder is
port(
reset : in std_logic;
clk : in std_logic;
operand1: in std_logic_vector(7 downto 0);
operand2: in std_logic_vector(7 downto 0);
carry : out std_logic;
sum : out std_logic_vector(7 downto 0)
end fulladder;
architecture Behavioral of fulladder is
begin
process(reset,clk)
variable sum_t : std_logic_vector(7 downto 0);
variable carry_t: std_logic;
begin
if(reset = '0') then
carry <= '0';
sum <= (others => '0');
elsif(rising_edge(clk)) then
carry_t := '0';
for i in 0 to 7 loop
sum_t(i) := operand1(i) xor operand2(i) xor carry_t;
carry_t := (operand1(i) and operand2(i)) or (carry_t and (operand1(i) or operand2(i)));
end loop;
carry <= carry_t;
sum <= sum_t;
end if;
end process;
end Behavioral;
通过对上述代码的综合(XST),布局布线和后仿真,可以发现整个加法器是可以正常工作的。也没有毛刺的现象,避免了逻辑电路设计中最忌讳的一点。仿真时钟是100mhz。
整个设计过程是这样的:首先写出一位全加器的真值表,根据真值表画出卡诺图,化简卡诺图,写出了sum和carry的逻辑表达式。然后根据逻辑表达式写出上面的RTL级的代码。可见基础的数电知识还是很重要的。估计现在很少有人卡诺图了吧。
