电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » ISIM 中如何观察内部(或定义的中间)信号
2015-08-14 17:08:38     打赏
比如
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity test1 is
 port( clk : in std_logic;
 count:out std_logic_vector(3 downto 0));
end test1;
architecture Behavioral of test1 is
--signal fcount : integer range 1 to 24000000 :=1;
signal fcount : integer range 1 to 10 :=1;
signal count_tmp: std_logic_vector(3 downto 0):="0000";
signal clk1 : std_logic :='0';
begin
process(clk)
 begin
 if clk'event and clk = '1' then
 if fcount = 10 then
 fcount <= 1;
 clk1 <= not clk1;
 else
 fcount <= fcount+1;
 end if;
 end if;
 end process;
process(clk1)
 begin
 if clk1'event and clk1 = '1' then
 if count_tmp = "1001" then
 count_tmp <= "0000";
 else
 count_tmp <= count_tmp+1;
 end if;
 end if;
 end process;
 count <= count_tmp;
end Behavioral;
 如何在 ISIM 中观测 fcount,count_tmp,clk1 信号
