ISIM 中如何观察内部(或定义的中间)信号
比如
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity test1 is port( clk : in std_logic; count:out std_logic_vector(3 downto 0)); end test1; architecture Behavioral of test1 is --signal fcount : integer range 1 to 24000000 :=1; signal fcount : integer range 1 to 10 :=1; signal count_tmp: std_logic_vector(3 downto 0):="0000"; signal clk1 : std_logic :='0'; begin process(clk) begin if clk'event and clk = '1' then if fcount = 10 then fcount <= 1; clk1 <= not clk1; else fcount <= fcount+1; end if; end if; end process; process(clk1) begin if clk1'event and clk1 = '1' then if count_tmp = "1001" then count_tmp <= "0000"; else count_tmp <= count_tmp+1; end if; end if; end process; count <= count_tmp; end Behavioral;
如何在 ISIM 中观测 fcount,count_tmp,clk1 信号
