电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 【12.23更新】14的学习进度
共7条 1/1 1 跳转至页
【12.23更新】14的学习进度
2015-11-10 13:35:50     打赏
我的作业http://forum.eepw.com.cn/thread/277630/1#2第一次作业
http://forum.eepw.com.cn/thread/277630/1#3第二次作业
http://forum.eepw.com.cn/thread/277630/1#4第三次作业
第四次作业:uart控制LED流水灯转速http://http://forum.eepw.com.cn/thread/277630/1#5
第五次作业:定时器控制LED灯http://forum.eepw.com.cn/thread/277630/1#6
第六次作业:计算开机次数http://forum.eepw.com.cn/thread/277630/1#7
2015-11-10 13:40:51     打赏
首先打开软件,然后一路next下去就OK了然后要记得和谐啊,最后就大功告成啦
2015-11-10 14:23:40     打赏
#include "stm32f10x.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void);
void Delay(__IO uint32_t nCount);
int main(void)
  //uint16_t a;
  /* System Clocks Configuration **********************************************/
  RCC_Configuration();
  /* Configure all unused GPIO port pins in Analog Input mode (floating input
     trigger OFF), this will reduce the power consumption and increase the device
     immunity against EMI/EMC *************************************************/
/*  RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD |
                         RCC_APB2Periph_GPIOE, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;                                     //D1  D2
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_13;                 //D3, D4
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  while (1)
    GPIO_SetBits(GPIOC, GPIO_Pin_6);// D1亮
    Delay(0xAFFFF);
    GPIO_SetBits(GPIOC, GPIO_Pin_7 );        //D2亮
    GPIO_ResetBits(GPIOC, GPIO_Pin_6);        //D1灭
    Delay(0xAFFFF);
    GPIO_SetBits(GPIOD, GPIO_Pin_13 );        //D3亮
    GPIO_ResetBits(GPIOC, GPIO_Pin_7);        //D2灭
    Delay(0xAFFFF);
    GPIO_SetBits(GPIOD, GPIO_Pin_6 );        //D4亮
    GPIO_ResetBits(GPIOD, GPIO_Pin_13);        //D3灭
    Delay(0xAFFFF);
    GPIO_ResetBits(GPIOD, GPIO_Pin_6);        //D4灭
  /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
     initialize the PLL and update the SystemFrequency variable. */
  SystemInit();
  for(; nCount != 0; nCount--);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param file: pointer to the source file name
  * @param line: assert_param error line source number
  * @retval : None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
 额~说实话,这是在某论坛借鉴的,没成功不知道是我电脑抽风还是~
2015-11-10 18:33:53     打赏
01./**
02.  ******************************************************************************
03.  * @file    GPIO/IOToggle/main.c
04.  * @author  MCD Application Team
05.  * @version V3.5.0
06.  * @date    08-April-2011
07.  * @brief   Main program body.
08.  ******************************************************************************
09.  * @attention
10.  *
11.  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
12.  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
13.  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
14.  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
15.  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
16.  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
17.  *
18.  *
19.
20.    ? COPYRIGHT 2011 STMicroelectronics
21.
22.******************************************************************************
23.  */
24.
25./* Includes ------------------------------------------------------------------*/
26.#include "stm32f10x.h"
27.#include "stm32_eval.h"
28.uint16_t Dis_tab[]={GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8,//0
29.    GPIO_Pin_9|GPIO_Pin_12,//1
30.    GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_5,//2
31.    GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_5,//3
32.    GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_8|GPIO_Pin_5,//4
33.    GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_8|GPIO_Pin_5,//5
34.    GPIO_Pin_7|GPIO_Pin_12|GPIO_Pin_14|GPIO_Pin_13|GPIO_Pin_8|GPIO_Pin_5,//6
35.    GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12,//7
36.    GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14,//8
37.    GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14//9
38.    };
39.GPIO_InitTypeDef GPIO_InitStructure;
40.
41.void RCC_Configuration(void)
42.{
43.  RCC_DeInit();
44.  RCC_HSICmd(ENABLE);
45.  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
46.  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
47.
48.  RCC_HSEConfig(RCC_HSE_OFF);
49.  RCC_LSEConfig(RCC_LSE_OFF);
50.  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
51.  RCC_PLLCmd(ENABLE);
52.  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
53.  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
54.  RCC_PCLK2Config(RCC_HCLK_Div1);
55.  RCC_PCLK1Config(RCC_HCLK_Div2);
56.  RCC_HCLKConfig(RCC_SYSCLK_Div1);
57.  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
58.  while(RCC_GetSYSCLKSource() != 0x08);
59.  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
60.  GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
61.  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
62.  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
63.  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
64.  GPIO_Init(GPIOD, &GPIO_InitStructure);
65.  GPIO_ResetBits(GPIOD,GPIO_Pin_2);
66.}
67.
68.void GPIO_INIT()
69.{
70.   //GPIOB(数码管)初始化
71.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
72.  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
73.  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
74.  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
75.  GPIO_Init(GPIOB, &GPIO_InitStructure);
76.
77.  //按键初始化
78.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
79.  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;
80.  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
81.  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
82.  GPIO_Init(GPIOC, &GPIO_InitStructure);
83.}
84.//微秒延时
85.void delay_us(u32 n)
86.{
87.    u8 j;
88.    while(n--)
89.    for(j=0;j<10;j++);
90.}
91.//毫秒延时
92.void  delay_ms(u32 n)
93.{
94.    while(n--)
95.    delay_us(1000);
96.}
97.
98.
99./**
100.  * @brief  Main program.
101.  * @param  None
102.  * @retval None
103.  */
104.
105.int main(void)
106.{
107.    int i,j;
108.    RCC_Configuration();
109.    GPIO_INIT();
110.    GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);//关闭数码管
111.      while(1){
112.            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))//S3键按下
113.           {delay_ms(80);
114.           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){j++;}}//延时后S3处于按下状态,j++
115.        if(j%2==0){ //如果i是偶数
116.             if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))//S2键按下
117.           {delay_ms(80);
118.           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){i++;}
119.           }}//延时后S2处于按下状态,j++
120.                else{//如果i是奇数
121.                              if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))//S1键按下
122.           {delay_ms(80);
123.           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}}
124.                 }//延时后S1处于按下状态,j++
125.        if(i>30){i=0;}
126.           GPIO_ResetBits(GPIOB,GPIO_Pin_1);
127.           GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
128.        switch(i){
129.         case 0 :
130.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
131.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
132.         break;
133.         case 1 :
134.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
135.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
136.         break;
137.            case 2 :
138.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
139.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
140.            break;
141.            case 3 :
142.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
143.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
144.            break;
145.            case 4 :
146.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
147.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
148.            break;
149.            case 5 :
150.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
151.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
152.            break;
153.            case 6 :
154.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
155.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
156.            break;
157.            case 7 :
158.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
159.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
160.            break;
161.            case 8 :
162.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
163.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
164.            break;
165.            case 9 :
166.             GPIO_SetBits(GPIOB,GPIO_Pin_1);
167.             GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
168.            break;
169.                      case 10 :
170.           GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
171.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
172.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
173.                        delay_ms(10);
174.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
175.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
176.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
177.                        delay_ms(10);
178.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
179.                        delay_ms(10);
180.
181.            break;
182.                        case 11 :
183.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
184.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
185.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
186.                        delay_ms(10);
187.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
188.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
189.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
190.                        delay_ms(10);
191.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
192.                        delay_ms(10);
193.            break;
194.                        case 12 :
195.              GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
196.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
197.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
198.                        delay_ms(10);
199.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
200.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
201.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
202.                        delay_ms(10);
203.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
204.                        delay_ms(10);
205.            break;
206.
207.               case 13:
208.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
209.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
210.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
211.                        delay_ms(10);
212.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
213.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
214.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
215.                        delay_ms(10);
216.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
217.                     delay_ms(10);
218.            break;
219.
220.
221.                      case 14:
222.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
223.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
224.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
225.                        delay_ms(10);
226.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
227.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
228.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
229.                        delay_ms(10);
230.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
231.                     delay_ms(10);
232.            break;
233.                         case 15:
234.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
235.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
236.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
237.                        delay_ms(10);
238.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
239.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
240.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
241.                        delay_ms(10);
242.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
243.                     delay_ms(10);
244.            break;
245.                          case 16:
246.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
247.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
248.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
249.                        delay_ms(10);
250.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
251.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
252.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
253.                        delay_ms(10);
254.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
255.                     delay_ms(10);
256.            break;
257.                             case 17:
258.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
259.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
260.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
261.                        delay_ms(10);
262.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
263.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
264.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
265.                        delay_ms(10);
266.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
267.                     delay_ms(10);
268.            break;
269.                              case 18:
270.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
271.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
272.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
273.                        delay_ms(10);
274.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
275.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
276.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
277.                        delay_ms(10);
278.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
279.                     delay_ms(10);
280.            break; case 19:
281.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
282.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
283.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
284.                        delay_ms(10);
285.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
286.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
287.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
288.                        delay_ms(10);
289.                        GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
290.                     delay_ms(10);
291.            break;
292.                         case 20:
293.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
294.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
295.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
296.                        delay_ms(10);
297.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
298.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
299.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
300.                        delay_ms(10);
301.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
302.                     delay_ms(10);
303.            break;
304.                          case 21:
305.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
306.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
307.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
308.                        delay_ms(10);
309.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
310.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
311.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
312.                        delay_ms(10);
313.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
314.                     delay_ms(10);
315.            break;
316.                             case 22:
317.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
318.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
319.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
320.                        delay_ms(10);
321.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
322.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
323.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
324.                        delay_ms(10);
325.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
326.                     delay_ms(10);
327.            break;
328.                              case 23:
329.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
330.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
331.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
332.                        delay_ms(10);
333.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
334.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
335.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
336.                        delay_ms(10);
337.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
338.                     delay_ms(10);
339.            break;
340.                                 case 24:
341.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
342.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
343.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
344.                        delay_ms(10);
345.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
346.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
347.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
348.                        delay_ms(10);
349.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
350.                     delay_ms(10);
351.            break;
352.
353.                                 case 25:
354.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
355.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
356.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
357.                        delay_ms(10);
358.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
359.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
360.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
361.                        delay_ms(10);
362.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
363.                     delay_ms(10);
364.            break;
365.
366.                                 case 26:
367.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
368.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
369.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
370.                        delay_ms(10);
371.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
372.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
373.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
374.                        delay_ms(10);
375.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
376.                     delay_ms(10);
377.            break;
378.                                         case 27:
379.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
380.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
381.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
382.                        delay_ms(10);
383.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
384.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
385.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
386.                        delay_ms(10);
387.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
388.                     delay_ms(10);
389.            break;
390.                                                 case 28:
391.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
392.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
393.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
394.                        delay_ms(10);
395.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
396.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
397.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
398.                        delay_ms(10);
399.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
400.                     delay_ms(10);
401.            break;
402.                         case 29:
403.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
404.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
405.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
406.                        delay_ms(10);
407.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
408.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
409.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
410.                        delay_ms(10);
411.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
412.                     delay_ms(10);
413.            break;
414.                     case 30:
415.               GPIO_ResetBits(GPIOB,GPIO_Pin_15);//PB15 off
416.                        GPIO_SetBits(GPIOB,GPIO_Pin_1);//PB1  on
417.                        GPIO_ResetBits(GPIOB,Dis_tab[i%10]);
418.                        delay_ms(10);
419.                                    GPIO_SetBits(GPIOB,Dis_tab[i%10]);  //off
420.                        GPIO_ResetBits(GPIOB,GPIO_Pin_1);//PB1 off
421.                        GPIO_SetBits(GPIOB,GPIO_Pin_15);//PB15 on
422.                        delay_ms(10);
423.                        GPIO_ResetBits(GPIOB,Dis_tab[i/10]);
424.                     delay_ms(10);
425.            break;
426.    }
427.
428.    }
429.}
 参考某位仁兄滴
2015-12-14 12:35:19     打赏
  1. #include "stm32f10x.h"
  2. #include    "stdio.h"
  3. GPIO_InitTypeDef GPIO_InitStructure; // 声明结构体
  4. NVIC_InitTypeDef  NVIC_InitStructure;
  5. USART_InitTypeDef  USART_InitStructure;
  6. USART_ClockInitTypeDef  USART_ClockInitStructure;
  7. #define buff_size  16;
  8. char rx_buff[],rx_buff_count=0;
  9. void RCC_Configuration(void) ;
  10. void GPIO_INIT(void)  ;
  11. void USART_int(long BaudRate);
  12. void USART_SendStr(char *str);
  13. void delay_ms(u32 n)  ;
  14. void delay_us(u32 n);
  15. /****主函数 ****/
  16. int main()
  17. {
  18. RCC_Configuration();
  19. GPIO_INIT();
  20. USART_int(9600);
  21. GPIO_ResetBits(GPIOC,0xffff);//led全亮,提示程序开始
  22. delay_ms(200);
  23. GPIO_SetBits(GPIOC,0xffff);//led全灭
  24. USART_SendStr("USART Led Speed\r\n");//
  25. USART_SendStr("\n>");//
  26. while(1);
  27. }
  28. /****   配置RCC ****/
  29. void RCC_Configuration(void)
  30. {
  31. ErrorStatus HSEStartUpStatus; //  设置错误标志量
  32. RCC_DeInit(); //*将外设寄存器RCC重设为初始值
  33. RCC_HSEConfig(RCC_HSE_ON);//*打开外部高速时钟晶振HSE:
  34. HSEStartUpStatus = RCC_WaitForHSEStartUp(); //*等待外部高速时钟晶振工作:
  35. if(HSEStartUpStatus==SUCCESS)
  36. {
  37. RCC_HCLKConfig(RCC_SYSCLK_Div1);//*AHB使用系统时钟,负责外部存储器的时钟
  38. RCC_PCLK1Config(RCC_HCLK_Div2);//*APB1 负责DA,USB,SPI,I2C,CAN,串口2345,普通TIM
  39. RCC_PCLK2Config(RCC_HCLK_Div1);//*APB2负责AD,I/O,高级TIM,串口1
  40. RCC_PLLConfig(RCC_PLLSource_HSE_Div1,RCC_PLLMul_9);//*设置PLL输入时钟源72M
  41. RCC_PLLCmd(ENABLE);//*打开PLL:
  42. while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);//*等待PLL工作:
  43. RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//*设置系统时钟
  44. while(RCC_GetSYSCLKSource() != 0x08);//* 判断PLL是否是系统时钟:
  45. }
  46. GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  47. /*蜂鸣器*/
  48. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
  49. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  50. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  51. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  52. GPIO_Init(GPIOD, &GPIO_InitStructure);
  53. GPIO_ResetBits(GPIOD,GPIO_Pin_2);
  54. }
  55. /****延时 ****/
  56. void delay_us(u32 n)
  57. {
  58. u8 j;
  59. while(n--)
  60. for(j=0;j<10;j++);
  61. }
  62. void delay_ms(u32 n)
  63. {
  64. while(n--)
  65. delay_us(1000);
  66. }
  67. /**** 初始化GPIO ****/
  68. void GPIO_INIT(void)
  69. {
  70. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  71. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
  72. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  73. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  74. GPIO_Init(GPIOC, &GPIO_InitStructure);
  75. }
  76. /**** USART传输的波特率 ****/
  77. void USART_int(long BaudRate)
  78. {
  79. RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA和 usart1
  80. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  81. GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  82. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出 PA9作为US1的TX端,打开复用,负责发送数据
  83. GPIO_Init(GPIOA, &GPIO_InitStructure);
  84. GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //RX位于PA10
  85. GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入,PA10作为US1的RX端,负责接收数据
  86. //RX初始化PA10
  87. USART_InitStructure.USART_BaudRate = BaudRate;//波特率
  88. USART_InitStructure.USART_WordLength = USART_WordLength_8b;//USART_WordLength 在一个帧中传输8位数据(字节)
  89. USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位为一个字节
  90. USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验
  91. USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无流控制
  92. USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//收发模式
  93. USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;//时钟低电平活动,开启发送接受数据功能(usart 使能)
  94. USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low; //SCLK输出时钟低电平
  95. USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;//时钟第二个边沿开始数据捕获
  96. USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;//最后一位数据不从SCLK发出
  97. USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
  98. USART_Init(USART1, &USART_InitStructure);//初始化USART1
  99. USART_Cmd(USART1, ENABLE);//USART1使能
  100. USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//使能接收中断,在接受移位寄存器中有数据时产生
  101. USART_Cmd(USART1, ENABLE);
  102. //配置NVIC ,设置优先级分组,使用NVIC_Init对NVIC进行初始化
  103. NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);//选择中断分组4(先占优先级四位,从优先级0)
  104. NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择中断通道
  105. NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//抢占优先级1-15
  106. NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;//响应优先级1-15
  107. NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;//使能中断
  108. NVIC_Init(&NVIC_InitStructure); //初始化中断
  109. }
  110. /**** usart发送数据 ****/
  111. void USART_SendStr(char *str) //USART发送数据
  112. {
  113. while((*str)!='\0')
  114. {
  115. USART_SendData(USART1,*str++); //通过外设 USARTx 发送单个数据
  116. while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET); //检查指定的 USART 标志位设置与否
  117. }
  118. }
  119. /**** 取字符串中的数字 ****/
  120. unsigned int translate(char* pstr)
  121. {
  122. int s = 0;
  123. while(*pstr != '\0') //如果没扫到字符串的最后不停止
  124. {
  125. if(*pstr >= '0' && *pstr <= '9') //如果字符串中存在0-9的数字
  126. {
  127. s = s * 10 + *pstr - '0';
  128. }
  129. pstr++;
  130. }
  131. return s;
  132. }
  133. /****  点亮led****/
  134. void LED(char *S,char LEN) //(字符串,字符串长度)
  135. {
  136. int m,i;
  137. int a[8]={GPIO_Pin_0,GPIO_Pin_1,GPIO_Pin_2,GPIO_Pin_3,GPIO_Pin_4,GPIO_Pin_5,GPIO_Pin_6,GPIO_Pin_7};
  138. m=translate(S);
  139. GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  140. delay_ms(100);
  141. for(i=0;i<8;i++)
  142. {
  143. GPIO_ResetBits(GPIOC,a[i]); // 点亮LED
  144. delay_ms(m);
  145. GPIO_SetBits(GPIOC,a[i]); //熄灭LED
  146. delay_ms(m);
  147. }
  148. }
  149. void input_ASK()
  150. {
  151. char j;
  152. LED(rx_buff,rx_buff_count);
  153. rx_buff_count=0;
  154. for (j=0;j
  155. {
  156. rx_buff[j]='\0';
  157. }//判断读入信息是否结束,如果结束则准备下一次读入
  158. USART_SendStr("\n>");
  159. }
  160. /****接收中断****/
  161. void USART1_IRQHandler(void)
  162. {
  163. while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)  { } //判断接收中断是否打开
  164. if(USART_ReceiveData(USART1)==0x0d)
  165. {
  166. input_ASK();
  167. }
  168. else
  169. {
  170. USART_SendData(USART1,USART_ReceiveData(USART1)); //将数据传回给电脑
  171. rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
  172. rx_buff_count++;
  173. }
  174. USART_ClearFlag(USART1, USART_FLAG_RXNE); //清除中断接受完成标志位
  175. }
2015-12-23 17:23:58     打赏
#include <stdio.h>
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
EXTI_InitTypeDef   EXTI_InitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
int count=0;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
    /* PA10 USART1_Rx  */
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
void NVIC_Configuration(void)
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  NVIC_Configuration();
//USART_int(115200);
//  printf("config done...\r\n");
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 36000;
  TIM_TimeBaseStructure.TIM_Prescaler = 100;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
  while (1){
//if(flag == 1)
//  {printf("TIM2 interrupt......\r\n");
//flag = 0;
//else{GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);}
void TIM2_IRQHandler(void) //TIM3
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_Update );
//  flag = ~flag;
//  if(flag){
//  GPIO_SetBits(GPIOC,GPIO_Pin_1);}
//  else {GPIO_ResetBits(GPIOC,GPIO_Pin_1);}
/*flag++;
    if(flag == 50)
        {led = ~led;
         flag = 0;}
    if(led){
    else {GPIO_ResetBits(GPIOC,GPIO_Pin_1);}*/
    count++;
        if(count==1)
    GPIO_ResetBits(GPIOC,GPIO_Pin_0);
    if(count==2)
    if(count==3)
    GPIO_ResetBits(GPIOC,GPIO_Pin_2);
    if(count==4)
    GPIO_ResetBits(GPIOC,GPIO_Pin_3);
    if(count==5)
    GPIO_ResetBits(GPIOC,GPIO_Pin_4);
    if(count==6)
    GPIO_ResetBits(GPIOC,GPIO_Pin_5);
    if(count==7)
    GPIO_ResetBits(GPIOC,GPIO_Pin_6);
    if(count==8)
    GPIO_ResetBits(GPIOC,GPIO_Pin_7);
    if(count==9)
    count=0;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  /* Infinite loop */
  while (1)
 #endif
2016-01-19 10:21:17     打赏
7楼
第6次作业  计算开机次数
sfr IAP_DATA     = 0xE2;
sfr IAP_ADDRH     = 0xE3;
sfr IAP_ADDRL     = 0xE4;
sfr IAP_CMD      = 0xE5;
sfr IAP_TRIG     = 0xE6;
sfr IAP_CONTR     = 0xE7;
#define           CMD_IDLE  0
#define           CMD_READ   1
#define           CMD_PROGRAM   2
#define           CMD_ERASE   3
#define     ENABLE_IAP0x80
#define     ENABLE_IAP0x81
#define     ENABLE_IAP0x82
#define     ENABLE_IAP0x83
IAP_ADDRESS    0x2000
void IapIdle(void)
IAP_CONTR=0;
IAP_CMD =0;
IAP_TRIG =0;
IAP_ADDRH=0x80;
IAP_ADDRL =0;
unsigned char IapReadByte(unsigned int addt)
unsigned char dat;
IAP_CONTR=ENABLE_IAP;
IAP_CMD =CMD_READ;
IAP_ADDRL=addr;
IAP_ADDRL=addr>>8
IAP_TRIG =0x46;
IAP_TRIG =0xb9;
dat = IAP_DATA;
IapIdle();
return dat;
void Iap ProgramByte(unsigned int addr,unsigned char dat )
IAP_CMD =CMD_REOGRAM;
IAP_ADDRL=addr;
IAP_ADDRH=addr>>8
IAP_DATA=date;
IAP_TRIG =0x46;
IAP_TRIG =0xb9;
IapIdle();
void Iap EraseSector(unsigned int addr )
IAP_CMD =CMD_ERASE;
IAP_ADDRL=addr;
IAP_ADDRH=addr>>8
IAP_TRIG =0x46;
IAP_TRIG =0xb9;
IapIdle();
unsigned char Num=0;
void main(void)
unsigned long i=0;
Num = Iap ReadByte(IAP_ADDRESS+20);
Num++;
Iap EraseSector(IAP_ADDRESS);
Iap ProgramByte(IAP_ADDRESS+20,Num);
for(i=0;i
LED0=0;
DelayMs(100);
LED0=1;
DelayMs(100);
while(1);
共7条 1/1 1 跳转至页
